11-15-2009, 01:31 PM | #1 |
help with air-ride
I am planing on puting air bags on the back of my truck and need some help designing a system for my 59 chevy that i am making into a rollback so the air ride has to be strong, the air bags that I am using are off of a frieghtliner truck. what size air tank do I need? how big of a compresser? I also plan on running a air hose off of the system. how about valving. does any one have any experties in designing a good system
11-16-2009, 04:12 PM | #2 |
Re: help with air-ride
if your using the large airbags i would suggest an engine powered compressor. the electric one i have run's a lot to keep up with my settings. i have the simplest set up air ride makes and i kind of wish i had a larger tank and 2 compressors. if your bags are substantial look in to belt powered compressors. I'm sure an old school bus would have one.
set us up with as build site so we can see the progress... GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
11-16-2009, 04:20 PM | #3 |
that truck is bad a$$
11-16-2009, 04:27 PM | #4 |
Thanks mylow53 I will have to look at the belt powered unit then and see what I can come up with.
11-16-2009, 06:44 PM | #5 |
You might want to check into a York AC compressor. Im kind of a jeep nut too and have one to convert myself. Just do a search on "York on board air". You should be able to get at least 4cfm at 90psi, but I don't know if that will suit your needs.
11-17-2009, 11:14 AM | #6 |
Arkansas50's that York unit looks like the ticket, thanks for the input
11-19-2009, 09:07 AM | #7 |
Just picked up a york air conditioner compressor yesterday hope I have room,things are starting to get tight in the engine compartment.
11-19-2009, 01:20 PM | #8 |
Inner fenders are way over rated! Nice truck, if had too much money I would have an assortment of bulldog and COE trucks just to play with.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
