Old 01-21-2003, 01:45 AM   #1
tracy
Question Move My Truck??
MY MECHANIC BUDDY LIVES ABOUT 10 MILES AWAY. IF MY KNOCK IS INDEED A ROD KNOCK WOULD IT BE A GOOD IDEA TO DRIVE MY TRUCK TO HIS GARAGE? I CAN'T GET A HOLD OF HIM RIGHT NOW ANYWAY.......UNTIL I SHOW UP IN HIS DRIVE. I THINK IT IS A ROD KNOCK BECAUSE IT SOUNDS LIKE SOMEONE IS INSIDE TRYING TO GET OUT. IT IS MAINLY AROUND 1000 RPM BUT STILL EXISTS IN SOME FORM AT ALL LOW SPEEDS.
72 CHEYENNE 3/4 TON 4X4...14 bolt full float rear.4.10 gear and 350/350/np205 has a little needs a lot!
tracy is offline   Reply With Quote
Old 01-21-2003, 02:18 AM   #2
68 Suburban
68 Suburban's Avatar
I was once told to start disconecting spark plug wires until the knock goes away. One by one of course. When you find the cylinder that is the cause of the knock, dont put the spark plug wire back on. I have been told it will be "safer" to drive it that way, but I can't guarantee it.
68 Suburban is offline   Reply With Quote
Old 01-21-2003, 02:29 AM   #3
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
me i wouldnt try it can screw it up big time if the rod broke
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 01-21-2003, 02:40 AM   #4
Mudder
Mudder's Avatar
Check your oil level and water. Could just be a head gasket. Is it missing?
Mudder is offline   Reply With Quote
Old 01-21-2003, 10:35 AM   #5
tracy
I'LL CHANGE OIL TODAY. NOT REALLY MISSING THOUGH.. IT WILL BANG WITH A BLOWN HEAD GASKET LIKE THAT?
Old 01-21-2003, 12:47 PM   #6
Mudder
Mudder's Avatar
You dont have to change your oil ,just check to see it maybe it has water in it. Both of my head gaskets blew last year between the center cylinders on both sides and it sounded really bad. Ten miles.....I would have it towed.
Old 01-21-2003, 06:51 PM   #7
tracy
ITHINK IT MAY BE MAIN BEARINGS....I STARTED IT TODAY AND WAS LOOKING AROUND FOR WHAT THE HELL COULD BE MAKING THE NOISE AND SAW THAT THE BALANCER LOOKED LIKE IT WAS VIBRATING...THAT WOULD BE CAUSED BY THE MAIN BEARING WOULDN'T IT?
Old 01-21-2003, 06:52 PM   #8
tracy
OH AND IT SOUNDS LIKE A MIDGET WITH A CROWBAR TRYING TO GET OUT
Old 01-21-2003, 06:56 PM   #9
cableguy0
if its wobbling i wouldnt run that thing at all. would pull teh motor out and start tearing it down. do a total rebuild crank kit rods refinished new pistons ring etc. have the block checked at a machine shop to make sure its true. it will probably need bored and possibly align honed depending on whats up with that crank. wouldnt run it or u could ruin a block thats still useable.b/c if whatever is making all that racket lets go ur gonna have problems.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 01-21-2003, 07:09 PM   #10
truckman32
AND HOLDING ON TO THE C10
truckman32's Avatar
sounds like a warped crank or broken rod or crank could be ready to break is it steaming out the valve covers?
66 swb/ss chevy c10 SOLD
62 swb/fs chevy c10 :p SOLD
84 swb/fs chevy c10
91 sdime 383/th350
truckman32 is offline   Reply With Quote
Old 01-21-2003, 07:14 PM   #11
truckman32
truckman32's Avatar
i would drain the oil take the oil pan off and check for anything broke or loose i always unbolted the motor mounts and raised the motor also so you can get a good look but watch the raditor the fan might hit it when you raise it or just take fan of also
84 swb/fs chevy c10
91 sdime 383/th350
Old 01-21-2003, 07:32 PM   #12
tracy
HOW MUCH WOULD A NEW SET OF BEARINGS COST TO INSTALL?? I CAN'T AFFORD A FULL REBUILD RIGHT NOW AND IT SEEMS LIKE EVERYTHING ELSE IS STILL FINE. NO SMOKE OR MISSING AT LEAST.
Old 01-21-2003, 08:01 PM   #13
truckman32
truckman32's Avatar
well if your bearings are wore out then check your crank for groves if there is groves in your crank it will need to be turned or replaced just depends how bad the groves are and if it can be turned unless there is a broke rod ,or you have a warped crank or your balancer is shot . you might want to check the balancer first, hope this helped if you need anymore help email me... taking the plug wire off wont stop the crank from turning
84 swb/fs chevy c10
91 sdime 383/th350
Old 01-21-2003, 08:10 PM   #14
truckman32
truckman32's Avatar
sorry i didn't answer your ? how much a set of bearingds cost well if the crank is wore bad then you would be throwing your money away,did you take the oil pan off like i said i am almost sure you have a broke or loose rod i bought a truck once that sounds like the same problem so i rented a car dollie and towed it home dropped the oil pan and it was a loose main bearing i guess the young boys didn't tighten them or forgort when they rebuilt the motor,cheap buy though on my part like i always tell my nephews you never know until you get inside,
66 swbss
85 s10
86 f==d f15 xlt
95 intrepid
84 swb/fs chevy c10
91 sdime 383/th350
Old 01-21-2003, 10:43 PM   #15
racedvl
racedvl's Avatar
I'm sorry about your engine, but I'm sitting here cracking up over this sentance!! LMAO!!
racedvl is offline   Reply With Quote
Old 01-21-2003, 10:52 PM   #16
Stano
Stano's Avatar
Bought a nice 79 C20 once, guy said the motor was rebuilt but it knocked real bad as soon as they started it. Took it home and put a new water pump on it and drove it two years. Then sold it to a friend for a little profit and he drove it two more years then parted ways with it himself. All it was, was a water pump and the guy who sold it was a mechanic and used car sales person. He built the motor himself! LOL Moral of this story is if its off then replace it with new while you're at it.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Old 01-22-2003, 01:14 PM   #17
tracy
I KNOW ITS NOT THE WATER PUMP CAUSE WHEN CHANGING BRACKETS I HAD THE BELT OFF THE WATER PUMP AND IT MADE THE NOISE WHILE JUST THE POWER STEERING AND CRANK PULLEY WERE GOING.
