Do these tubular control arms fit on our trucks? They are for 73-87. I had these on my 66 truck (without the upper tubular) and they made my wheels bow in from the bottom.
http://www.stylintrucks.com/part.asp...3&partid=12899 |
Re: Do these fit on 60-66?
I believe these are what you're lookin for... http://www.djmsuspension.com/applica...63C10Parts.htm
...or give DJM a call.
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482 Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985 “Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!” - Hunter S. Thompson Last edited by Sicboy; 11-15-2009 at 11:34 PM. |
They look the same. I wonder what the difference is??
Sunburst C10!!!
the 73-87 arms have a wider track width so they are longer
they will work on a 63-72 if you are using 73-87 spindles and rotors you also have to have the correct upper for 73-87
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 11-16-2009 at 12:37 AM. |
So I have upgraded to drop spindles and disc brakes ( I bought as a kit). I dont know if they are combatible with these tubular control arms. Do you think they would work if I got the uppers for 73-87?
Sunburst C10!!!
yep they should
Gage 1967 C10 Shortbed Stepside |
