crossmember??
im looking to put a ls motor and 4l60e or 4l80e in my 72. i know i have to put a special crossmember in. my question is who makes these and how much do they usually cost?? i would like to find a reasonable one for i dont want to have a fortune tied up in a crossmember..thanks,,robbie
Re: crossmember??
Same here, i'm going with an LT1 and a 4l60e
Re: crossmember??
anyone??
Active Member
Re: crossmember??
Just curious what you worked out or went with in so far as the 4l80e cross-member?
"The Great State of Florida" |
Re: crossmember??
If it is 2wd you can use the stock transmission crossmember and maybe move it. There are lots of motor mounts and adapter plates for the 2wd aplications. Pacific fabrication makes an engine crossmember for 4WD LS swaps but a minimum 4 inch lift is needed. If you want a 4wd LS swap at a stock ride height will take some custom work. I am working on that now. Lots of information in my LS swap thread in my signature.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Re: crossmember??
Did he disappear(LSX72). No posts since Nov. Would be nice to see another LSX install.
Re: crossmember??
Last activity was 2/03 so he might still be around?
