Old 11-16-2009, 06:42 AM   #1
CUSTOM_1O
HaV0KSR559<~~~
CUSTOM_1O's Avatar
Exclamation truck bed question
so currently there is no wood bed kit in the bed right now and the weather is getting crappy so there it would be pretty dumb to slap some fresh out in there until summer time atleast i was wondering what i could do in order to get the bed back on the truck ??? shoot me some ideas of what you guys have in mind seen done or have had done thanks alot...
...1969_CUSTOM_1O
FLEETSIDE_LONGBED
V8_THREE-FIFTY
[COMPLETE-EDELBROCK]
[PERFORMANCE-SERIES]
[CAM_CARB_MANIFOLD]
...TURBO-400_TRANNY...
CUSTOM_1O is offline   Reply With Quote
Old 11-16-2009, 10:00 AM   #2
mvfd70
mvfd70's Avatar
Re: truck bed question
If you're just wanting to have something to make a bed floor for winter, then I'd say put a piece of plywood down. Easy to take back out if/when you want to put the correct planks back in.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 11-16-2009, 11:24 AM   #3
Shyguy
Junior Member
Shyguy's Avatar
As a temporary bed floor for my lwb stepper I put a piece of 3/4 in plywood down with a rubber mat over it.
It works for now.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 11-16-2009, 12:16 PM   #4
slomotion
Old Duffer
slomotion's Avatar
^^^x3
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 11-16-2009, 12:19 PM   #5
Ackattack
Ackattack's Avatar
For my 69 truck, No buck, I took a piece of 3/4" pressure treated plywood and cut it into the appropriate sized strips and used 1-1/2 wide flat bar strips to hold it down with.
So far it's holding up good.
Ackattack is offline   Reply With Quote
Old 11-16-2009, 04:19 PM   #6
CUSTOM_1O
HaV0KSR559<~~~
CUSTOM_1O's Avatar
very good info guys...
but if i did do so what would be the best way to mount the plywood???
i dont really want to use the strips or take the time to cut them in strips id just like it plywood all the way through... and if i did do this how would i have to mount it threw the original holes or could i get away with just four main bolts for now in each corner of the bed???
thanks to alll
...1969_CUSTOM_1O
FLEETSIDE_LONGBED
V8_THREE-FIFTY
[CAM_CARB_MANIFOLD]
Old 11-16-2009, 05:29 PM   #7
slomotion
Old Duffer
slomotion's Avatar
I'd be inclined to do three sets of three. Three across the front, three across the middle, and three across the back. I'd use 5/16 with big washers on the top. That oughta do it for a temp. set up.
and WC T5 trans.
'81 G10 Shorty Van
Old 11-20-2009, 02:16 AM   #8
CUSTOM_1O
HaV0KSR559<~~~
CUSTOM_1O's Avatar
3/4 plywood from homedepot???
...1969_CUSTOM_1O
FLEETSIDE_LONGBED
V8_THREE-FIFTY
[CAM_CARB_MANIFOLD]
Old 11-20-2009, 10:16 AM   #9
slomotion
Old Duffer
slomotion's Avatar
Sure, that would work, especially in your area.
and WC T5 trans.
'81 G10 Shorty Van
