Another big brake company
I found this on abs power brakes site http://www.abspowerbrake.com/bigbrake.html
Re: Another big brake company
Wonder if the use different calipers in the front than the ones pictured. Looks as though they're wasting that extra inch of rotor.
It'd be alot cooler if you did
I'm really liking those 14.5's but I'm also curious about the fit with the rotors?
Anyone have prices? Last edited by smashingchuck; 11-16-2009 at 01:45 PM. |
i ordered a set, and will let ya know bout the fit soon
2nd prices??
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
you'll have to contact them, but doug there, said its 3600$... that includes everything
drop spindles, drilled slotted rotors, brake lines, electric master cyl., everything neccessery to install.... so we'll see how well the kit goes together.... Last edited by 68 short step; 11-16-2009 at 09:48 PM. |
Front and rear?
Dam!! thats high! I like big brake kits and all but do you really need 14.5 inch rotors? Not to hate on the guys who can afford it and want it, all I'm saying is do u really need this for daily drivers, show vehicles? Sounds like you would need for a track truck.
#11 | ||
One day...
![]() Join Date: Apr 2008
![]() ![]() Quote:
I can do a whole lot to my truck for $3600 Last edited by scotts62; 11-16-2009 at 10:29 PM. |
if you price simular kits from bear, wilwood, ssbc you'll find that this kit is priced about par with the other manufactures.... but what this kit has to offer the others dont, is their all electric powerbooster/master cyl. setup (which is 1G by itself)...
#13 |
I know the calipers are copies of the mustang Kelsey - Hayes 4 piston used 64-69.But the pistons are a lot bigger tho.Yeah there priced about the same as a big disc kit from anywhere else but the one piece rotor would be nicer then the 2 piece most others use.
#14 |
Never Ending Projects
Sure hope you have much better luck with the electric boster setup then my buddy did. After a number of attempts to get it (and the whole brake system) to work correctly, we pulled everything and went with a Baer setup and a Hydraboast. Works awesome now!
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#15 |
They have a Hydraboast and normal brake booster if you want to use those im sure you can.
#16 |
Yeah but by the point he decided to swap everything, he had already had them replace the electric booster once and the rear brake kit (not the big brake kit you show) was based off the Cadilac calipers, which is a craptasic system and never got to work correctly. He had a ton of money into the car and just went with a known good system.
#17 |
id be instrested to know what the prob. was... the electric portion of the master cyl. is a seperate piece, and if it wasnt working then the master would function as a normal (non powered) master...also i know these calipers are based off brembo, so thats good..
#18 | |
His Hyrdatech hydroboost has been working great once it was bleed fully. You have to blead the booster (unrelated to the brake fluid) system with the power steering system to get it working correctly.
#19 |
GM ONLY BABY!!!
Sweet, Ya I didn't see a price either. All I need is the rotors and calipers. I'm curious how much for just that.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
#20 |
![]() Join Date: Sep 2004
13 inch full kit with booster is 2k just called
#21 |
they are massive, 14.5" rotors all round, 4 piston polished alumnium brembo style calipers, and braided brake lines....also got another electric style master cyliner/power booster....
the calipers are 12" long and nearly 7" wide, and they look BIG, as well as the ROTORS themselves....everything installed with no problems, except the rears....the rear caliper mounting bracket mounting holes were off by .25"..keep in mind tho, im running a ford 9"..im gonna call the company (abspowerbrake.com) and let them know, so they'll send me the correct brackets...but here is how big they are, and them mounted on the truck with 22s and 20s ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by 68 short step; 11-26-2009 at 01:43 AM. |
#22 |
#23 |
Looks good let them know which 9 inch you have there is 3 different ones.I bet it will stop like a sports car when you get it done.
#24 |
#25 |
GM ONLY BABY!!!
Looks awesome. Can you give us the weight of what each caliper weighs? And also the weight of each rotor. I am curious, and maybe some others are too. I seen these in the Super Chevy magazine. Thanks!!
