11-16-2009, 10:18 AM | #1 |
Motor Mounts
Newbie here guys, In the process of building a 72 SWB. Putting in a 6.0 LS with probably 4L80E. using the CPP tubular SBC mounts, which set of frame holes would I need to use. The front set or the back set to move motor back a few inches?
Thanks DON |
11-16-2009, 11:15 AM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Motor Mounts
Do you already have the perches? They will set the engine on the front two perch holes, which puts the engine about 4" forward, how are you cooling the engine? If you don't I have a set I can't use, pm me if you are interested.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-16-2009, 11:54 AM | #3 | |
Re: Motor Mounts
Thanks DON |
11-16-2009, 02:04 PM | #4 | |
Re: Motor Mounts
11-16-2009, 03:22 PM | #5 |
Re: Motor Mounts
I am using an F-body radiator and E-fans.
there are alot of variables, you just need to get it in there and find out. When you get ready for headers let me know, I am shipping the Doug Thorleys!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
