seat belt retractors
Does anyone have any info on the seat belt retractor mechanism; such as replacement or insallation or repair?
Tot Roddin'
Re: seat belt retractors
bttt for an answer...
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
if yours arnt working for a lobuck try.. id spray they with lubricant// i've found 40year old moving parts love the lube tho rarely get it
Pull the cover off and then extract the belt all the way out. Take a stiff paint brush and clean it out as best as you can then use a very small amount or lubricant on the moving parts. Let it retract in and out a few times then pull it out again and wipe off any excess you can. Reinstall and hope you never need them.
Kevin LFD inc. |
Has anyone here actually changed out the retractor cylinder? I've tried the lubricant route without success.
Any body else here done any repair or replacement of the seat belt retractors?
Moderator
![]() Join Date: Jul 2006
attempted mine = FAIL. I wound them up before putting them back together and they won't retract. The actual mechanism is simple and easy to take apart and clean so I'm not sure where I went wrong. Hope sombody else chimes in...
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
Finally took the time last night to get my belts apart,cleaned and reassembled. It was actually a pretty simple procedure when all was finished.
looks simple. mine wont retract anymore either... Not sure how to wind them up correctly or maybe the spring isnt strong enough. I honestly dont remember if they retracted before I took them apart... Any tips?
