Old 11-16-2009, 02:50 PM   #1
JimmyFloyd
Aux. Battery Tray
Auxillary battery tray. Removed from a 1970 GMC Suburban. There is a little rust on the tray, but the side panels are in good shape. $75/bo plus shipping.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 11-17-2009, 07:57 AM   #2
olblue60@aol.com
member
Re: Aux. Battery Tray
Do you have the wiring for the second battery setup? Thanks!
John
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 11-18-2009, 12:47 AM   #3
JimmyFloyd
I don't know how complete the wiring is, but there is some there with the selector switch to select single, dual, or off. Same type of switch often found on fire trucks. That would be extra as I was planning on keeping that for my own dual battery setup, but will take offers.
Old 11-18-2009, 07:45 PM   #4
woodridge
woodridge's Avatar
Since the tray is bad it could be cut and I think the sides could be put in a USPS flat rate box. $65 shipped?
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 11-19-2009, 02:36 AM   #5
olblue60@aol.com
member
I would have a hard time guessing what it is that you would accept, but here goes. $30. Please feel free to counter offer if this isn't good, as I cant see what and dont know what it is that I am offering a price for. Thanks
John
Old 11-20-2009, 05:55 PM   #6
JimmyFloyd
OldBlue. I will get out there and get pictures hopefully soon of the old wiring.
Woodridge: The tray isn't in too bad of shape, but I will check to see if it'll fit in a medium flat rate. if it will, then i can do $65 shipped. if it needs a Large one, then I would need $70. Would you care if it is one cut down the center or two cuts near the edges, but not into the bracket area (might help it fit better) If it won't fit into either of those, I will find a box and get a quote.
Old 11-20-2009, 07:11 PM   #7
olblue60@aol.com
member
Thanks Jimmy, No big rush here. But I am interested!
John
Old 11-21-2009, 10:58 AM   #8
woodridge
woodridge's Avatar
Two cuts would be ok as I'll be replacing the tray. Do you take PP? Either way, PM me your info.
Old 11-23-2009, 02:35 PM   #9
olblue60@aol.com
member
ttt
Old 11-24-2009, 10:41 AM   #10
woodridge
woodridge's Avatar
PM recieved and repied to. PP sent.
Thanks.
Old 11-24-2009, 02:51 PM   #11
JimmyFloyd
Battery tray sold.
Pictures of the Wiring is coming. I check it today and the only thing I see mission is the passenger side negative cable. The switch and the wires to the positives and the starter are there.
Old 11-24-2009, 04:18 PM   #12
olblue60@aol.com
member
If you end up removing the wiring for me, could you wrap each wire end with a piece of masking tape and lable where it connects? I'm electrically chalanged. Thanks Jimmy!
John
Old 11-24-2009, 04:26 PM   #13
JimmyFloyd
Sure thing. It's actually easy on this one.
This is the switch mounted on the Passenger side inner fender. One wire to the starter, one wire to each battery
wire to driver's side (in front of radiator) and negative cable (not connected to anything, just sitting there.)
Driver's side didn't have a negative cable (truck didn't come with batteries) but I assume that the stock ones on this side would be fine.
The switch has the options of NONE, 1, 2, BOTH for the batteries.
Old 11-25-2009, 08:26 AM   #14
olblue60@aol.com
member
Hi Jimmy
Thanks for the pictures. I notice that what you have is a switch and I am looking for the automatic battery isolator box. I'm gonna have to let this pass.
John
