1970 GMC Suburban 3/4 Ton 4x4 For parts/restore
Ok, i am looking to sell or part this truck. I have begun parting it out some, but would offer it up for sale to someone if they want it. I will offer it in a couple configurations, so read up. Will consider requests for parts, but selling whole takes precidence.
Ok, before I list the configurations for sale, I will say that I am keeping the front end (fenders, hood, bumpers and brackets, core support, grill, inner fenders, headlight harness, and other misc parts.) I will also be keeping the rear bumper and brackets, gas tank, and aux gas tank, Power steering setup, dual battery switch, hitch and bell. Also, this truck has a good title, but is titles as a 73, not a 70. Not sure how hard this is to correct, but the VIN matches the body and glove box, and it decodes to the proper 1970 year. Rust. The body has rust in the quarters, bottoms of the cargo doors, upper roof around the doors and windshield, and the normal rockers and floors. The passenger side and rear seat center floor sections look to be in good shape, driver's is more rotted. There was some bondo used previously, so I can't say whether the rear wheel wells are actually good, or not. Bottoms of the front doors and third are fairly solid, and may just be surface rusted. Rear inner wheel wells, and spare tire well are rust free. Ok, configuration #1: Mostly complete. This would include the Motor, trans, transfer case, and HO52 rear with NoSpin. 350 motor, TH400 trans, NP205 from what I can tell. It will include the title, glove box, original cluster, all doors and glass, and the front seat. Include the aftermarket air with rear air, although I have started removing it, so new hoses would be needed. The Interior carpet in the rear and the hold downs are all there. There are a couple brackets missing off the rear doors. All interior wiring and engine wiring will be left. I have never had the motor/trans running. The previous owner said it was running a couple years ago when he got it, but had not run it himself. Tranny does shift to and from park fine for rolling it. No issues there. Motor/trans/transfer case may be original to the truck, as they are what it is called out for having. I have not checked the numbers because I have to remove the AC compressor and brackets. I did drain the coolent and it was nice and bright and green, and the transmission fluid when i remove the External trans cooler was nice and bright and red, so I have a feeling that they should both be decent. All suspension components are good. I am asking $1200/bo for this configuration. 2nd Configuration. Frame, suspension and body. This would include the title, Glove box door, body, frame, front suspension and rear suspension. Cluster, Motor, Trans, and Transfer Case would not be included. The rest of the stuff will be included. $750 3rd configuration: Same as the second, just without the No Spin rear. Must provide your own rear to make it a roller and help switch them. $450. Last Configuration. Body cuts, title, and glove box. This you would have to come and cut out whatever parts you want. Would need to be done by thanksgiving. I will take care of the frame and rest of the body. AC parts not included. No frame or suspension. $300 It must be picked up in 13901 or 13790 (depending on where I have it stored at the time. I am Open to ALL offers, as well as offers on the parts. I have a couple people interested in the rear, and some interested in the doors. I NEED to have this gone by the end of the month, but might be able to keep it a little longer if someone is interested in the first 2 options. Also, I will be pulling parts off as I go, cause I need to get it out of my parents back yard (starting to sink into the ground) so let me know. Pictures of the truck when I bought it and at varying states are here: http://s282.photobucket.com/albums/k...ent=70suburban and http://s282.photobucket.com/albums/k...82/70Suburban/ I do not have the 2nd seat, interior side panels, some rear door brackets, or any of the headliner supports. ![]() ![]() ![]() ![]()
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 Last edited by JimmyFloyd; 11-17-2009 at 10:49 AM. |
Re: 1970 GMC Suburban 3/4 Ton 4x4 For parts/restore
JimmyFloyd,
This is Rick - I bought some parts from the Burb a month ago. What kind of shape are the rear carpet hold down strips in? How much with shipping to 14004? Pics? Thanks. |
![]() ![]() Join Date: Jan 2002
How much for the tow hooks.
![]() ![]() 1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
#4 | |
I also have the headliner side supports set aside for you if you still need them. ![]() As for the tow hooks everyone asks about, they are available here: http://67-72chevytrucks.com/vboard/s....php?p=3623070 As I said before, the front end is actually in the process of being disassembled, and is no longer complete like the pictures. The rest of the truck looks similar though.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
How much for the locking front hubs?
![]() Join Date: Sep 2008
how much for the body. no reardoors or cluster? no front clip
andrew |
Not sure on the front hubs. Make me an offer for now.
And I sent you a PM about the body.
![]() Join Date: Aug 2007
how much do you want for the front and back rears?
$300 for the rear. I believe it is 4:10 with the No Spin.
$100 for the front with no hubs. $250 for the Spicer hubs. Open to offers on everything.
Just looked up prices for the Spicer hubs, so I am going to Lower the asking price to $200 for those.
I am open to offers on everything. Will do $350 for the front and the rear, or $400 and the frame (without title) can be included. Currently have someone interested in the body, but if they pass, it will be available. If you just want the front half for a crew, that would be fine, and be cheaper than the whole body, as I would like the rear 1.5' for another project. Body would include the title, unless the person didn't want it, then it could go with the frame. I am trying to get most of this gone by mid december, but would prefer to have it gone this weekend.
Here are pictures of the Spicer hubs:
![]() ![]() ![]() Also added some pictures of other parts of the truck. Some notable areas are: The spare tire well with no rot ![]() ![]() AC components: ![]() Rear End/Axle: ![]() Rear carpet Hold down strips (and the coolent that was removed from the truck) ![]() ![]() Transmission with Fairbanks Performance sticker on it (shift kit. goes by Superior performance now I believe) ![]()
Sorry but those hubs wont fit on mine. how much for he drive shaft and shiping to 99321?
#13 |
![]() Join Date: Oct 2008
could I get some pics and prices for the front door armrests and front door panels, also the dash pad. shipping to 14075 Thanks
My Chevys 79 caprice classic 70 c/10 69 k/10 03 silverado |
#14 |
Sorry for the delay. was in FL last week for business. I will try and get pictures this week of them.
#15 |
P/M sent on those hubs
#16 |
member
I'm interested in the body panel below the rear cargo doors where the lower door latches. Its a bolt in part. With shipping to 20901.
Thanks! John
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
#17 |
I Like Mine With No Shine!
![]() Join Date: Apr 2009
what kind of shape are the green seat belts? Any chance you have the set of three?
Michael ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
#18 |
#19 |
![]() Join Date: Aug 2008
Hello. i was wondering if you had sold the spare tire well? And how much you wanted for it if you still have it?
Thanks Matt
1972 Cheyenne Super 1/2 ton lwb 2wd 350/350 green and white 1970 Suburban Ambulance 1/2 ton 2wd 350/350 white 1969 CST 20 lwb 2wd 350/4spd white/turquoise |
#20 |
I would like to have thefront turn signals in the grill as a full package and the power steering pump pulley. shipped to 66801
1969 GMC 3/4 Ton 4x4 2" Lift, A/C, PS, PB 383 Stroker, 700R4, 205, 4.10 GM Medium Bronze (Copper Poly) no new nick name yet. She is to pretty to be the Beater. http://67-72chevytrucks.com/vboard/s...d.php?t=241855 |
#21 |
![]() Join Date: Feb 2000
are the hubs still available?
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
#22 |
Turn Signals and Power Steering components are being kept for my truck.
Seat Belts I believe are decent, but will have to check and see if it is a set of 2 or three for the front. might have the middle seat ones still. There was no third seat. The body panel below the rear door is there, but has some rust through on it. Still trying to get over to get door panel pictures. As for the hubs, I have an offer on them, but it is not for the asking price, so I will consider another offer. If I haven't gotten a better offer by the weekend, they'll be sold for the current offer.
#23 | |
#24 |
Bump. i will be going to Norfolk, VA next week, so I might be able to deliver some of the larger parts there.
#25 |
hi jimmy are rear inner wheel tubs still there are they rusty? do they look like this?
