Old 11-16-2009, 04:02 PM   #1
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
how to test a tach???
Hey guys, I am trying to figure out how to test out a tachometer to see if it works. What is a way to test it without it being in a vehicle? I remember there is ways to do it with power to it, but I don't remember the process. Thanks guys, Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-16-2009, 04:03 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: how to test a tach???
Signed in for this one too...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-16-2009, 04:37 PM   #3
JimKshortstep4x4
The way I test a tach is to hook power to the tach, (ground the case, positive to the + post on the tach). I then run a wire to the "Tach" connection of an HEI distributor or to the - side of a coil if points are used.
If a tach is good it will register the rpm. If it is out of calibration I use my Snap-On Tachometer as a reference to adjust the tach to. Both tachs can be hooked up at the same time.
I have also used my distributor machine to test tachs on and it is a similar procedure but instead of a battery, I use a 12 volt DC battery charger.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-16-2009, 04:38 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I don't know why you couldn't lay the cluster or tach on the cab floor or seat, run a jumper wire to the "unfused ignition" terminal on the fuse panel, one to the HEI "Tach" connector on the distributor, one to ground, and start the truck up.
LockDoc
Leon
Old 11-16-2009, 04:42 PM   #5
71blksuper4x4
SWB 4x4 Collector
Leon, well this is a camaro tach dash conversion I want to test and then sell. I just want to make sure that the tach works before I sale. My truck is out of commission right now, but we have a gm truck that we could hook up to the dizzy. Thanks Jim for your help as well. Trevor
TREVOR
