![]() Join Date: Feb 2008
Rear Gears
Can a ring & pinion from a 67-69 12bolt Posi Camaro rear be used in a 68 C10 12bolt Posi rear? My truck has 3.73's currently but I have access to a 3.07 from a Camaro rear & wondered if I could swap these to get a little better highway rpm just for now.
If this won't work, where should I get a set that will? In other words, what vehicle & years - looking for cheap. TIA.
Bryan '52 Bel Air 2dr HT - in pieces '68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed “Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin "And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery) |
its all about the +6 inches
Re: Rear Gears
The initial answer to your question is no, it won't work.
Car 12 bolt rears and truck 12 olt rears were not the same. Also, a 3.07 gear won't work in a 3.73 rear end. Plus, I'll assume you don't know this, but you can't just toss gears in. It takes some special tools and you have to know how to do it. if it isn't just right, they will die in no time. I only assume you don't know how to set gears becouse anyone who does know how, wouldd probably not want to run used parts. Your best bet would be to locate a 3.07 rear end out of a junk yard truck and buy the whole thing. |
#3 | |
Never Ending Projects
Re: Rear Gears
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
