11-16-2009, 07:15 PM | #1 |
Ebay Junky
Any experience with a TBI 350 and supercharger?
I found a good deal on a 350 TBI out of a 93 truck with a whipple supercharger, was thinking about dropping it into the 83 i just bought. The trans will be a 4l60E probably. This motor should put out just over 300 ponies right? What else should i take from 93 truck to help out with the motor swap?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain.. 1983 Chevy c10 swb 2wd - possible 350tbi supercharged... |
11-16-2009, 07:24 PM | #2 |
Jonny
Re: Any experience with a TBI 350 and supercharger?
it may be a no brainer, but definately grab the engine wiring harness and the ecm
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
11-17-2009, 05:51 AM | #3 |
>130dB Moderator
O2 sensors, exhaust manifolds, anything you can basically
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
11-17-2009, 10:28 AM | #4 |
Junior Member
definitely get the ECM... double check the harness just in case there is a piggy back chip in-line in the harness. With the Whipple chargers you either chipped it, or sent your ECU back in to get modded. The other thing you can look at doing is changing to a smaller pulley and installing a 454 throttle body but you are going to need to find a smart guy with the ECU. The guys at Whipple might be able to help point you in the right direction.
