Old 11-16-2009, 09:44 PM   #1
TwoFiftyShifter
To make an I-6 highway-able... Gears or tranny?
I'm putting together a '64 shortbed this winter, and don't plan on spending a ton. With keeping the 230 and wanting to cruise at 65 on the highway, the current setup will not do it. I have the 3 on the tree and 3.73 gears. What's the better route, 3.08 gears or say..... a T5 tranny? I would be putting in a new clutch anyway, does anyone run an I-6 with a T5? Have a bench seat as well not sure about the shifter location....
Everytime I search for T5 I get people wanting to put it behind small blocks and other people saying it will break.... Thanks for the help.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 11-16-2009, 09:51 PM   #2
terd ferguson
terd ferguson's Avatar
Re: To make an I-6 highway-able... Gears or tranny?
I know guys who run T5s with inlines. I think you want one from a truck to work with your bench. If I recall, the shifter is farther forward than on the car T5. You should be able to cruise all day with that. Or you can change the rear. Might be cheaper, adapters for the T5 can get pricey. If you're on the hamb, search there. There are a ton of these swaps with documentation and tons of info.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson
1955 2nd Series Chevy "King Of Trucks"
terd ferguson is offline   Reply With Quote
Old 11-16-2009, 09:56 PM   #3
2manyprojects
2manyprojects's Avatar
I would go with a T5. I put 3:08's in a 66 with a 250 and it was a dog. The T5 cant handle the torque of a strong V8 but should be fine behind a 6 .
2manyprojects is offline   Reply With Quote
Old 11-16-2009, 10:43 PM   #4
TwoFiftyShifter
Yeesh, I meant to put this in the 60-66 thread... Yeah I figured the 3.08 would be a dog but it would be way easier. I guess ill look into the T5 swap, thanks. Also, I have read that the S10 trannies were rated for 220lb torque, the little 230 isnt even near that, is it? And for calculating gear ratios, whats the top rpm for a six? 3800 or so?
1982 K10 SWB
Old 12-10-2009, 06:32 PM   #5
okfine101
There is another option. Replace your current Tranny with one that has overdrive (58-62 pass). The bolt up is the same an you can keep your three on the tree. You will need to add a little additional electrical (relay & kickdown switch).
okfine101 is offline   Reply With Quote
Old 12-11-2009, 01:30 AM   #6
playinsafe44
I have a '73 longbed with a 250, 3 on the tree, and 3.73 gears. I can get it going 65 on the freeway but the hills usually slow me down a little. It does take a little longer to get up and going too. The only changes I have made is a holley/weber 2 bbl, and a stock style HEI. I think my set up would do 10X better if I put larger jets in the carb though. It's starving right now.
playinsafe44 is offline   Reply With Quote
