Old 11-16-2009, 10:11 PM   #1
cwilkie
Chance
cwilkie's Avatar
How to mount radio?
I trimmed my dash for a modern style radio; however, I do not know how I am going to mount the radio. The radio will fit in the opening but I do not know how to properly secure it so it doesn't move or bend my dash. Does anyone have any pointers?
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 11-16-2009, 10:36 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: How to mount radio?
mines in there tilted up,free bump id like to know too lol
John
1999 Toyota Tacoma 4x4
Old 11-16-2009, 10:40 PM   #3
DZL1
One day.....
DZL1's Avatar
Use some type of backstrap that you can bolt 1 end to back of radio and other end to vehicle.
DZL1.
DZL1 is offline   Reply With Quote
Old 11-16-2009, 11:51 PM   #4
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
DZL1.
The factory radio had a strap in the back which bolted to the underside of the dash. The reason they did that was because the Delco radio was so big and heavy. Modern radios are light and small, so a lot of guys just use the tuning and volume control shaft nuts to support the radio.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 11-16-2009, 11:56 PM   #5
jackyl9999
jackyl9999's Avatar
I am interested in a solution for this also. Does anyone know of a adapter? I know adapters are available for most new veh. when replaceing a factory radio with din size cd player. I would like to find something that will cover up the poor cutting job I did when I was younger and dumber.
steve
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 11-17-2009, 12:16 AM   #6
Sacramento70
Blazer Fanatic
Sacramento70's Avatar
this is what im using for thew outside
1970 Chevy blazer
Sacramento70 is offline   Reply With Quote
Old 11-17-2009, 12:43 AM   #7
tecky11
on my truck the radio was mounted to a plate that bolted to the dash. i just taped my radio to it and bolted it to the dash adn so far it has worked pretty well for me
tecky11 is offline   Reply With Quote
Old 11-17-2009, 03:13 AM   #8
red71c10
The Red Menace
red71c10's Avatar
I thought metal plumber's tape was the universal solution for mounting stereos. That's what I've used and seen used more than anything.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 03-17-2015, 02:10 AM   #9
'68 Newtricks
'68 Newtricks's Avatar
steve
Searched for this topic before creating a new thread, luckily it's already created so I'll bump it. I'm running into this problem too. I really want to run an aftermarket stereo, especially since the dash has already been cut by a PO. The problem, like mentioned earlier, is the cut isn't the best. Seems the old dial holes are always left.
So, I'd like to run something like the above picture, if available to purchase. I'd also like to secure the radio cage as best as possible. If straps are the answer, so be it. My K5 runs an aftermarket aluminum dash, so it's DIN opening is plenty strong, but that doesn't help my C10.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 03-17-2015, 11:19 AM   #10
Zeroman
Zeroman's Avatar
A board member makes a great Billet Aluminum Radio Plate to fill the hole, clean it up, and I am sure it helps steady the radio.
I've got one, love it.
Check it out in Parts For Sale
http://67-72chevytrucks.com/vboard/s....php?p=7063487
Zeroman is offline   Reply With Quote
Old 03-17-2015, 11:43 AM   #11
michael bustamante
michael bustamante's Avatar
there should be a stud on the back of the radio to mount a piece of plumbers strap to. screw the other end of the strap to the firewall or if the oem radio mount is still attatched to the firewall, screw it to that
1967custom
michael bustamante is offline   Reply With Quote
