Old 11-17-2009, 01:20 PM   #1
Anadrol
Anadrol's Avatar
Adding Power Locks and Windows
If i want to add power locks and windows to my '78 K10, am I OK just buying the kits from LMC Truck, or should I try to find factory parts from a different vehicle for added strength and durability?
If your answer is the 2nd one, where do I start looking?
How much would I expect to pay? (The kit on LMC is $90 for the doors, $170 for the windows)
thanks.
Anadrol is offline   Reply With Quote
Old 11-17-2009, 01:29 PM   #2
TLoz
Re: Adding Power Locks and Windows
PM sent.
TLoz is offline   Reply With Quote
Old 11-17-2009, 01:31 PM   #3
Mr.Scary
Project Optimus Prime
Mr.Scary's Avatar
Im curious 2 know tha same info could u send me a PM 2 or just post tha info.
84 SWB work in progress
89 burb 1500 (parts pig) LOL
08 ford focus (I know, I know) Wifes car
"I said it b4 and i'll say it agian wiring is my worst enemy":devil:
Mr.Scary is offline   Reply With Quote
Old 11-18-2009, 01:25 PM   #4
BIG V
Smile Re: Adding Power Locks and Windows
ive seen alot of doors in the pick your part wrecking yards out there for 35.00 and up each door, the good thing about a pick n pull is you can pull the power door harness out of the truck you get the doors out of..
BIG V is offline   Reply With Quote
Old 11-18-2009, 01:46 PM   #5
jwa76fleetside
jwa76fleetside's Avatar
yes please post the info rather than pm.....i wanna know too
76 Chevy Fleetside
63 Lincoln Continental w/ Ford Racing 460 (550hp)
2012 VW GTI
2013 Escalade
2008 Harley
jwa76fleetside is offline   Reply With Quote
Old 11-18-2009, 10:59 PM   #6
locab36
locab36's Avatar
I'm in the middle of swapping over to PW and PL's on my 86. I bought a complete cab from a wreck that had all the correct color interior door panels and complete wiring harness needed. You'll be hard pressed to drill the holes in the doors and door jambs w/out the doors being off the truck. The harness is installed but haven't had time to put the guts back into the doors yet. Even though the windows worked before removing they were slow. I plan on new motors for the window regulators. I also plan on cleaning and greasing the tracks and wheels on the regulators.
John
Locab36
1936 low cab 1/2 ton
1956 BMW R25/3
1968 Moto Guzzi V7
1969 BMW R100/2
1986 Silverado SWB
2007 Harley FLHTP
2011 GMC SWB 4x4 Z71
http://www.flickr.com/photos/locab36...7623329816080/
locab36 is offline   Reply With Quote
Old 11-18-2009, 11:09 PM   #7
sailed2japan
Jonny
sailed2japan's Avatar
I would suggest using oem parts from a junk yard. I just did this on mine and the harness went in easily. I put the whole doors on my truck so I didn't have to mess around installing the motors.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 11-20-2009, 06:00 PM   #8
Anadrol
Anadrol's Avatar
I need some more help with this.
I cannot replace the whole doors because the truck has a new paint job, so that would be dumb to do.
I need to either buy a kit from LMC or another aftermarket source, or go the junkyard/OEM route with a full rip and replace process. This goes for Locks AND Windows.
Cost is not really a factor. I'll gladly pay a pro to do this, but I just want to give that pro the best kit right off the bat.
Old 11-20-2009, 07:32 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
My suggestion is you find a donor vehicle. Look at Burbs as a good source as "most" of them came with PW & PDL. If you can snag the doors and "complete" harness your miles ahead.
Take the doors apart and get everything you need at one time. Install in your doors and enjoy.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-21-2009, 07:22 AM   #10
andrewmp6
And make sure the motors work before you put them in your truck.
andrewmp6 is offline   Reply With Quote
Old 11-21-2009, 11:05 AM   #11
68 TT
Still plays with trucks
68 TT's Avatar
You want to try to find a donor with a similar fuse panel design as your truck. Blade fuse for blade fuse and glass fuse for glass fuse. The connectors used to wire it into the truck are different. If you get the right one it will just plug right into the stock fuse panel. The wrong one and you will be doing some custom wiring.
I got the Suburban doors from a newer donor as well as the cross over harness but also found an older two door donor to get the wiring and driver side two window switch out of.
I haven't had the time to do the swap yet but will document the process of the conversion, wire harness integration between the two styles of wiring and the 4-door to 2-door control wiring clean up.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
