Old 05-19-2002, 04:34 PM   #1
PushinPebbles
My dad's 68
PushinPebbles's Avatar
Lightbulb Borg Warned T-56 6-speed
Does any body have any expeirences w/ them???
Do you think they would handle a BB car???
yesss im talking about in cars not truck
Jack
Jack M. 14
67 C-10 SWB 355 built T-350 tranny hurst shifter 15x8 &15x10in corvette rallys slammed**hopefully bagged this summer**
88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires
69 SWB-parts
71 LWB-parts
72- LWB-parts
grand dads truck 68 C-10 stepside fuel inj. 350/700R-4*soon in audi silver*
Jack M.
67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts
4 12 inch Lightning Audios
87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ******************************
Dad's truck
68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more
84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames
S/N=BIGGYTYME@aol.com
(hydros)
"No fat chics, truck will scrape"
PushinPebbles is offline   Reply With Quote
Old 05-19-2002, 04:49 PM   #2
SCOTI
SCOTI's Avatar
Post
They are factory installed behind the viper V-10(488ft/lbs) so 'yes' they will live behind a big block but that doesn't mean they're indestructable.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-19-2002, 04:54 PM   #3
PushinPebbles
My dad's 68
Post
Do you mean the sam ones that are in the F-bodies? T-56s.........Jack
Jack M. 14
69 SWB-parts
71 LWB-parts
72- LWB-parts
Jack M.
Dad's truck
(hydros)
Old 05-19-2002, 06:02 PM   #4
Project1970
14.1 @ 96MPH
Project1970's Avatar
Post
Darn good transmissions. I don't know how Richmond sells those $3000 ROD 6-speeds when there's these for less than a third of that... I've seen specs on 'em such as 450lb/ft for 24 hours continuous...and they do install them behind the Viper, even in the new one with the bigger V10...
Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 05-19-2002, 06:26 PM   #5
SCOTI
SCOTI's Avatar
Post
Input & output shaft dimensions are the diff between GM's & Vipers. The new viper engines for '03 are same size as last years just tuned to squeeze more power. If you consider all that's needed to change to a T-56 the Richmond is comparetively priced since it doesn't require as many mods to install if you are already running a muncie or T-10 in an older car + w/the Richmond you can choose the ratios that best suit your combo, not so w/T-56's.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-19-2002, 06:43 PM   #6
mikep
Used to have a truck
mikep's Avatar
Post
OK where can I buy a T56 for under a grand? I'll be on it now!
No truck :-(
mikep is offline   Reply With Quote
Old 05-19-2002, 09:51 PM   #7
Jesse 67 c-10
Jesse 67 c-10's Avatar
Post
Think one of those could be swapped in to one of our trucks? Is there anything strange about them that would make the swap difficult? That would be a sweet tranny to have!
Jesse
Near Saskatoon, Saskatchewan, Canada. 67 c-10, Long fleet, Newly swapped front disks, 5 lug rear end, 327 v-8 with Vortech heads, edlbrock performer rpm air gap manifold, 1406 carb and comp XE 256 cam. Backed by a getrag 5 speed and 1 piece driveshaft. Finnally running, almost driving! www.geocities.com/chevy67jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 05-20-2002, 04:41 PM   #8
PushinPebbles
My dad's 68
Talking
$3000.......$1000.......Hmmmmm thats alot.
I as wondering about stealing one from a wrecked F-body from the wrecking yard
in staunton (well i know the people
there,,, as well as the rest of my family)
Jack
Jack M. 14
69 SWB-parts
71 LWB-parts
72- LWB-parts
Jack M.
Dad's truck
(hydros)
Old 05-20-2002, 04:53 PM   #9
SCOTI
SCOTI's Avatar
Post
They require a diff clutch set-up: hydraulic pull instead of manual push which requires a hydraulic clutch mstr.cylinder & a certain flywheel + the usual yoke, driveshaft length adj's, & floorpan mods if necessary. Have you priced a good clutch for a late model lately...OUCH. Still would be a cool swap, just more work than the Richmond.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-20-2002, 07:05 PM   #10
Project1970
14.1 @ 96MPH
Post
I've seen LT1s and T56's on eBay for under $2000 all the time. There doesn't seem to be many right now...getting one from a wrecked F-body is probably the best way to go. And why not take the LT1 too?
The clutches aren't that bad, really; stick with the GM ones, like the hybrid LT1/4 clutch we've got in our '94 Z28. One of the better ones you can get and also one of the cheaper ones.
Old 05-23-2002, 02:56 AM   #11
jmil1974
Ain't we cute?
jmil1974's Avatar
Post
If you search and are patient, you can get a decent one for a grand or so. Make sure it's from an LT1, LS1 trannies won't bolt up. Getting the matching engine IS the way to go, then the LS1 is viable. That's my plan in the next 2 years or so.
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES!
FOR SALE $3900
jmil1974 is offline   Reply With Quote
Old 05-23-2002, 07:15 AM   #12
jflem3
jflem3's Avatar
Post
there is also what is called (the aftermarket T-56) which has a manual speedometer output ,rather then the electric from the production T-56. Lake wood makes a bellhousing for the t-56 that will allow you to use a standard clutch and flywheel and even a mechanical clutch release if you desire. I got my T-56 for $800 out of autotrader and I got the flywheel, clutch, bellhousing, and hyd. slave cylinder.
Jim
Ferndale, MI
69 camaro ss
71 c-20custom deluxe suburban
72 c-10base suburban
79-VW scirocco Gt-3 race car
Jim
Davisburg, MI
69 Camaro SS LT-1/6-spd
71 C-20custom deluxe burb 402/400
(gonna get back to it)
72 C-10base burb 350/3-spd
79-VW Scirocco GT-3 race car 2.0L/5-spd
02 chevy suburban LT Supercharged dropped on 22's
jflem3 is offline   Reply With Quote
Old 05-23-2002, 07:18 AM   #13
jflem3
jflem3's Avatar
Post
also, If you have a monster big block you can have the viper mainshaft put in the production GM t-56's which bring them up to the 500ft# production rating.
Jim
Ferndale, MI
69 camaro ss
Jim
Davisburg, MI
