Old 11-17-2009, 07:12 PM   #1
deek114
deek114's Avatar
8-Lug bolt pattern
I just purchased a frame to a 1968 C-20. I was wandering if the new chevy and gmc 2500 and 3500 rims would bolt up since they are 8-lug rims???
deek114 is offline   Reply With Quote
Old 11-17-2009, 07:55 PM   #2
1lowdiesel
1lowdiesel's Avatar
Re: 8-Lug bolt pattern
yup. i have wheels off my dmax on my 68 gmc.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 11-17-2009, 10:52 PM   #3
extd56
extd56's Avatar
How well do the center caps fit on the old trucks?
extd56 is offline   Reply With Quote
Old 11-18-2009, 12:57 AM   #4
tncdrew
tncdrew's Avatar
These were off a 2009 2500HD, the caps off a 1996 2500. To use the newer factory centercaps, you have to buy the special factory style external thread lug nuts for SAE wheel studs, (Newer GM trucks have metric wheel studs)
tncdrew is offline   Reply With Quote
Old 11-18-2009, 02:37 AM   #5
deek114
deek114's Avatar
hey thats good to know i almost bought a set of these rims today but they said it only fit 88-09 so i didnt get them. thanks a lot everyone
Old 11-18-2009, 03:13 AM   #6
map3doc
I got some of thoses rims today the front center caps will fit. The rear center caps dont seem like they want to go along witht the program and because of the floating rear end any one have an ideas or already over came this problem.:fry
map3doc is offline   Reply With Quote
Old 11-18-2009, 07:14 AM   #7
eagleuh1
eagleuh1's Avatar
Mine fit with the Lugnut king SAE lugnuts for newer rims. Mine were 2003 steel slots off a 2500 HD. The rear center cap doesn't fit the DANA 60 rear. I'll add picture when I can use Photobucket.
eagleuh1 is offline   Reply With Quote
Old 11-18-2009, 10:13 PM   #8
tncdrew
tncdrew's Avatar
That's why I ended up using the centercaps from a 1996. They are actually deeper than the newer style caps that came with the '09 wheels I'm running, (i've also got the Dana 60 full floating rearend).
The '96 caps fasten the same way with the external thread lugnuts.
Old 11-18-2009, 10:17 PM   #9
extd56
extd56's Avatar
Any pictures of the centercaps and what years to look for? Thanks
