Old 11-17-2009, 09:05 PM   #1
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
Quick Queston
1st, has anyone cut the cups for airbags on the front suspension, if so how much without the airbag rubbing on the lower control arm when deflated, or low psi.
2nd, what front brake lines are longer and will bolt up to my 71-72 front disc setup? 73-87?
it sits higher with the bag so im not happy, need drop spindles but still want it lower.
Thanks guys.
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 11-18-2009, 11:24 AM   #2
BAGNDRAGIT
BAGNDRAGIT's Avatar
Re: Quick Queston
Bump, Anyone?
Previous:
1969 Volkswagen Bug
Old 11-18-2009, 12:20 PM   #3
nastyc10
nastyc10's Avatar
Re: Quick Queston
back when I had cups, I cut them down to 1.5 inches and I did a little grinding around the inside edges of the arm where the bag may touch. I had slam RE-7's and aired out they barely rubbed. As for brake lines I'm running braided stainless from inlinetube for a 72' with no problems.
nastyc10 is offline   Reply With Quote
Old 11-18-2009, 12:24 PM   #4
BAGNDRAGIT
BAGNDRAGIT's Avatar
Re: Quick Queston
Awesome, Thank you nastyc10. are you running modified LCA's now, or aftermarket?
Previous:
1969 Volkswagen Bug
Old 11-18-2009, 02:07 PM   #5
nastyc10
nastyc10's Avatar
Re: Quick Queston
I'm running a stock set off a 74' with a flat plate bolted across the top for the bag to sit on. I also have a dropmember with 2.5 inch spindles so it sits way low.
