Old 11-17-2009, 11:12 PM   #1
rigon4
rigon4's Avatar
Need help t-5 5 speed trans
Ok i got a 400 ci small block and a t-5 out of a 87 trans am for free that my friend just got because i talked the price down by half for the car "My friend wanted the bolt in ford 9 inch out of it for his 86 ta" So how do i know if it is a v8 trans the number on it is WG 13-52-157 Thanks Jeff
1981 K-5 Blazer 2wd
1985 C-10 Short step
1988 C-10 Suburban
rigon4 is offline   Reply With Quote
Old 11-18-2009, 04:50 PM   #2
rigon4
rigon4's Avatar
Re: Need help t-5 5 speed trans
ttt anyone??
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 11-18-2009, 09:30 PM   #3
SGTHohensee
SGTHohensee's Avatar
Honestly, it won't matter. I've seen 290hp 350's destroy V8 T5's. They're notoriously weak. Even a "World Class" Mustang T5's won't live long behind a torquey small block. All that said, yes yours is a V8 T5.
1352-157 GMC 1986 V8 F Cars V8 LG4-LG9 U 2.76 2.95 1.94 1.34 1.00 0.63
Here's your id guide.
T5 ID Guide
Josh Hohensee
1979 Midnight Black SWB
I'd attach a picture, but photosucket sucks.
SGTHohensee is offline   Reply With Quote
Old 11-19-2009, 07:04 AM   #4
Back in Black 66
Back in Black 66's Avatar
I have personal experience with those weak tranny's. had one in my 66 short step side with a 350hp small block. the trans went out in two months. these trucks are to heavy and as stated above 290hp or up and they crumble.
Back in Black 66 is offline   Reply With Quote
Old 11-19-2009, 10:08 AM   #5
68 TT
Still plays with trucks
68 TT's Avatar
Behind a 400 in a truck it won't last a week.
GM wouldn't even allow you to order the TPI 350 with the T-5. It is just plain a weak trans.
I went through a pile of T-5's in my 83 Z/28 and it only weighed 3400 pounds and had a mild 305. Now imagine the torque of a 400 and a 4000+ pound truck.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 11-19-2009, 12:15 PM   #6
rigon4
rigon4's Avatar
It will not have the 400 in it but worse I have a very strong 355 I had built for my 2wd 81 blazer I was thinking t-5 instead of th400 than put 4.56 in the rear and not the 3.73/4.11 I want
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 11-19-2009, 12:45 PM   #7
68 TT
68 TT's Avatar
I would sell it and find a T-56. They are rated for about 425 hp from the factory depending upon which vintage you get and have the aftermarket support to make them live in 9-second drag cars and 600+ hp Vipers so it should work great in your Blazer.
The double overdrive is pretty nice too. My 98 Camaro had the T-56. After I put in 4.10 gears I was still only at 1900 RPM at 70 mph in 6th with tires that were under 26" tall.
Old 11-19-2009, 06:45 PM   #8
gmclowsierra
dont do it . my buddy has a 400 with a t5 and blew the bottom of the case apart, we have it down to a science to change, 45 minutes in and out
gmclowsierra is offline   Reply With Quote
Old 11-20-2009, 12:23 PM   #9
Damien
Damien's Avatar
Wow, I knew these weren't the strongest transmissions, but I didn't know they were that bad. I'm glad I decided not to use one behind my 4.3. I was afraid this might happen and I would be out the cost of the clutch and flywheel.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
