Old 11-17-2009, 11:26 PM   #1
BGRAFX
Tips to Adjusting or Aligning Headlights
Guys,
I did a front end conversion and need a quick tip on how to align my headlights...
I went from a 91gmc Suburban front end to 81 yes I know thats reverse for most of you but that's what I wanted to do since I was born in 1981.
Also if anyone knows how to run both hi and low beams all the time. Obviously I would have to change the hibeam light but which wire do I change.
BGRAFX is offline   Reply With Quote
Old 11-18-2009, 01:00 AM   #2
3r!c84
Badass
3r!c84's Avatar
Re: Tips to Adjusting or Aligning Headlights
run both at the same time????? why
or u can just change the arond so the high beams are up top and lows on the bottom
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-18-2009, 01:06 AM   #3
Stitch
Location: Where I come from, it's cornbread and chicken...
why? because they are brighter...that's why...
there should be a thread on here on the headlight relay upgrade...you can hook both the lows and highs into the high beam relay if you want all 4 highs...that's what I did...still need to adjust my headlights though...lol
Stitch is offline   Reply With Quote
Old 11-18-2009, 01:07 AM   #4
3r!c84
Badass
3r!c84's Avatar
lol yeah true i guess
-00 Saturn 5spd
1/4:13:90
Old 11-18-2009, 10:49 AM   #5
BGRAFX
I can't figure out how to set the lights just perfect. What's the trick?
Do I park 5 feet away from my garage door and then set the lights to shine at x height to be level???
Currently one is shining into left field and the other is too low on the road.
And I would like to wire my lights so the all 4 plus my bumper lights are on all the time for running lights. I don't want to be in Hi-beam mode all the time. That would just blind other drivers. I figure these trucks have 2 lights stacked on top of each other why not use them.
I was going to wire them all together on the original 91gmc front end so that all 4 would be on but never did. I just think it looks dumb having 2 lights out considering never use hi-beams.
Old 11-18-2009, 11:24 AM   #6
Jonboy
Slots go on anything!
I have always used the garage door method with good results.
Old 11-18-2009, 11:49 AM   #7
BGRAFX
That's my question...What is the garage door method. I've heard of it just don't know exactly how to execute it so that my lights aren't too hi or too low. please enlighten me....
Old 11-18-2009, 01:36 PM   #8
95 S_Trucker
95 S_Trucker's Avatar
trial and error, line em up on a garage door where they look good, then take it for a spin, if the lights are amied too high or too low, just pull up to the garage door and move them where they need to be, and take it for another drive
whe i do the garage door thing. i stay about 20-25 feet away from the garage door
95 S_Trucker is offline   Reply With Quote
