Old 11-18-2009, 01:31 AM   #1
cstm68
cstm68's Avatar
bagged truck guys
what are you doing about hood hinges when bagged with 20'' or bigger wheels , it seems that when aired out you need to trim the inside of the fender and remove the inner fender well, leaving no place to bolt the hood hinge. what are the alternatives??
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 11-18-2009, 02:45 AM   #2
nastyc10
nastyc10's Avatar
Re: bagged truck guys
I have some on order from nathan @ Porterbuilt streetrods. He just came out with them and they are slick! There is a thread on it in the suspension section for more info.
nastyc10 is offline   Reply With Quote
Old 11-18-2009, 09:14 PM   #3
smbrouss70
smbrouss70's Avatar
... and right now would be a good time to install them since you are re-working your firewall.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 11-18-2009, 09:45 PM   #4
cstm68
cstm68's Avatar
thats what i was thinken
Old 11-18-2009, 10:11 PM   #5
PBFAB.COM
PBFAB.COM's Avatar
I will have an install and step by step instructions posted up on my web-site within the next couple days for all to see.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-23-2009, 01:39 AM   #6
PBFAB.COM
PBFAB.COM's Avatar
http://porterbuiltstreetrods.com/site/?p=98
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-24-2009, 01:18 AM   #7
cstm68
cstm68's Avatar
thanx nate, i will definitely be contacting you about a set of these soon
Old 11-24-2009, 09:48 AM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
cstm68.... are you just bagged, or do you have other modified components on your truck?
When you mentioned bagged and running 20's the first thought that came to mind is what kind of BS do you have on your wheels. To accomodate for the inner lip on the front and rear fenders, you have to make sure the BS will work with an air'd out truck.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-24-2009, 10:20 AM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
You could always do this mod also....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-24-2009, 09:49 PM   #10
cstm68
cstm68's Avatar
any info on that??
Old 11-24-2009, 10:00 PM   #11
smbrouss70
smbrouss70's Avatar
Rokcrln did a How-to here... http://67-72chevytrucks.com/vboard/s...d.php?t=218253
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 11-24-2009, 10:17 PM   #12
kev2809
low n' slo
kev2809's Avatar
wow, whos red truck is that?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
