11-18-2009, 03:19 AM | #1 |
lowering question
i was just wondering. im wanting to put 3/5 drop springs on my truck. do i need to c-notch the frame? thanks,,,robbie
11-18-2009, 07:33 AM | #2 |
Retired Air Force Veteran
Re: lowering question
No C-Notch needed but you may consider a Super Track Bar and a Shock Relocator Kit (both of which I bought from ECE). Currently, I'm running with a 3/6 Spring Drop. Good Luck
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
11-18-2009, 07:57 AM | #3 |
no you do not need a c-notch...I am running a 4/6 ECE drop on mine...
I agree about the shock relocator kit and the super track-bar.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
11-18-2009, 09:35 AM | #4 |
Tot Roddin'
As several have posted, a c-notch will not be "required" on a 3/5 or even a 4.5/6 drop. However, if you plan on hauling things in the back of your truck (wood, scrap, etc.) you will probably bottom out more since you are closer to the frame. A c-notch will give you the added space if you intend to haul items with your truck.
So far for my setup (4.5/6) I have yet to bottom out.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
11-18-2009, 02:26 PM | #5 |
probably wont be anything hauled in the back of this baby,,lol..thanks guys.
11-18-2009, 03:19 PM | #6 |
Tot Roddin'
Then it sounds similar to my truck. It ocassionaly hauls some coolers, a canopy tent, and a BBQ. Everything else is hauled in my DD.
Good luck with the install, and I would highly recommend ECE (Early Classic Enterprises).
11-18-2009, 03:37 PM | #7 |
which shocks are you guys running? stock or the drop shocks?
11-18-2009, 03:44 PM | #8 |
Tot Roddin'
I am running the KYB drop shocks offered by ECE w/ shock relocators. Smooth/clean ride.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 11-18-2009 at 03:44 PM. |
11-18-2009, 03:49 PM | #9 |
do the shocks lower any or just give it a better ride with the springs?
11-18-2009, 03:53 PM | #10 |
Tot Roddin'
The shocks themselves don't lower the vehicle, they however work with the lowered springs and the suspension geometry to keep it as close to factory spec as possible. If you attempted to retain OE shock mounts the shock would sit to flat, and if you attempted to use OE shocks w/ shock relocators they would be either to long or to short (sorry I'm not sure which on, but I know they wouldn't work)
11-18-2009, 03:55 PM | #11 |
oh, ok i see thanks very much. ill be buying shocks too!!
11-18-2009, 04:10 PM | #12 |
Tot Roddin'
Contact the guy's at ECE (Stan/Mark) and they will set you on the right path. Their parts might have a higher price tag than CPP but with the remarkable customer service, and technical support, you will not regret buying from them. I have not ordered from CPP but several on the board have and have been left waiting parts for several weeks, if not months.
11-20-2009, 04:16 AM | #13 |
HaV0KSR559<~~~
Is the shock relocator kit really needed with a 3 5 or can u get by without it
...1969_CUSTOM_1O
FLEETSIDE_LONGBED V8_THREE-FIFTY [COMPLETE-EDELBROCK] [PERFORMANCE-SERIES] [CAM_CARB_MANIFOLD] ...TURBO-400_TRANNY... |
11-20-2009, 01:59 PM | #14 |
chevellelover
its a good idea to get shocks because i didnt do it on mine and it rides like total crap. its a very stiff ride and if you hit a pothole in the front, it sounds like something is breaking...... its worth the extra money.
1978 Trans Am 400/4speed Year One Snowflakes 1980 c10 shortbed 1999 Suburban 5/7 drop US Mags Roadsters 1999 GMC Sierra Classic 4x4-MINT 2015 Challenger Scat Pack 6.4 8 Speed |
11-20-2009, 03:25 PM | #15 |
Tot Roddin'
chevellelover is right.... do it right the first time around; money well spent to say the least.
11-21-2009, 04:56 PM | #16 |
chevellelover
yes please get the correct materials!!!!!!!!!!!!!!!!! i tried to be cheap with mine and i have ended up with soooo much hassles AS in trashed wheel bearings and a new brake caliper. early classic is the way to go!!!
11-22-2009, 11:36 AM | #17 |
Sierra Grande Club
Can someone post a picture of the shock re-locaters? I'd like to see the difference and how they mount.
Thanks, s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
11-23-2009, 09:44 AM | #18 |
Tot Roddin'
s/t, the shock relocators actually utilitze the same mounting holes as the originals, they are just change the mounting locations.
11-23-2009, 03:20 PM | #19 |
HaV0KSR559<~~~
lol im not trying to be cheap my question was do i need shock relocators but now that i put the kit in i now know there is no need for them to be relocated
...1969_CUSTOM_1O
11-23-2009, 04:18 PM | #20 | |
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
11-24-2009, 09:12 AM | #21 |
Tot Roddin'
Here's the best I can do guy's.... like I mentioned above, they're not really "relocated" they just change the mounting point for the shock not the bracket.
The old mounts (first 2 pics): The new mounts (last 2 pics):
11-24-2009, 12:25 PM | #22 |
Is 3" on the front the lowest a guy can go without the spring being sloppy in the housing? IIRC someone said there spring was sloppy when the had there truck jacked up but I can't recall what spring that was.
68 Camaro - 327 Original Red on Red Car 69 GMC LWB - Built 350 a Blast To Drive 69 GMC LWB - "Green Machine" One Family Truck 70 Mercury Marauder - Future Project |
11-24-2009, 03:09 PM | #23 |
Tot Roddin'
69GMCor70Chevy, I believe you are correct. Front 3" drop springs have the tendency to come out of the bucket when the front of the truck is jacked up.
11-24-2009, 07:08 PM | #24 |
The oddest Todd around
Wouldn't it be better to use a 2 inch drop spindle and a 1 or 2 inch drop spring in the front?
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
11-24-2009, 08:02 PM | #25 |
Here are some good pictures....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
