Wiper problem
My once fancy, two speed windshield wipers are now only moving in slow. Is this likely the switch or the motor?
Hook'em |
Re: Wiper problem
have you cleaned and lubricated the wiper towers and linkage pivot points?
Between Trucks...
Re: Wiper problem
You should be able to take a jumper wire from the connector that goes to the switch and ground it out. If the motor works in both speeds it's the switch. If it's the switch, I put some epoxy on the back of the new one to keep it from coming apart. The repop switches are pretty crappy.
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 11-18-2009 at 10:33 AM. |
Its a Truck Thing......
Re: Wiper problem
The wiper motor works off of negative switching, if the wiper switch is loose or is poorly grounded = poor wiper motor movement,,,,make sure the switch is mounted tight and has a good ground to the dash....
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time Last edited by 71meangreenc10; 11-18-2009 at 10:10 PM. |
Re: Wiper problem
Thanks for the info. Sounds like I have checking to do this weekend.
Hook'em |
