Old 11-18-2009, 02:08 PM   #1
c10seconds
c10seconds's Avatar
ART strong arms kit 67sb. Good or bad idea?
I am new to the board and have been able to get TONS of resourceful info. Thank you all!!!!
I recently purchased the ART strong arms kit for my 67 short bed. My truck has all stock suspension minus the lowering springs. Im running 500+hp to the wheels and Im wondering if this purchase was a good idea before I start to install.. not sure if cutting into the frame is such a good idea And ive been told that the stock truck arms are hard to beat. Can anyone help???
c10seconds is offline   Reply With Quote
Old 11-18-2009, 06:13 PM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: ART strong arms kit 67sb. Good or bad idea?
You can't go wrong with the ART arms. If you decide to upgrade to a drop member in the future you can still run the ART arms.
Why would you need to cut the frame?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 11-18-2009, 08:14 PM   #3
c10seconds
c10seconds's Avatar
Its the rear strong arms kit and Im going to have to cut a small c-notch into the frame. I have mixed feelings on c-notching.
Old 11-18-2009, 08:18 PM   #4
c10seconds
c10seconds's Avatar
Heres the kit
Old 11-18-2009, 10:46 PM   #5
Wild83C10
Wild83C10's Avatar
A c-notch will allow the suspension to travel a bit more so the ride should be nicer. Why are you worried about cutting into the frame?
Ride Tech stuff is quality stuff not only material wise but also well engineered. I don't think you will be disappointed with that kit.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 11-19-2009, 01:44 AM   #6
OARNGESI
OARNGESI's Avatar
Did you get the kit on the phx cl
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 11-19-2009, 02:16 AM   #7
c10seconds
c10seconds's Avatar
I did get the kit from phx cl. I picked it up from a guy in tucson. Were you in line? I got a smokin deal on it
Old 11-19-2009, 02:22 AM   #8
OARNGESI
OARNGESI's Avatar
No i just seen it on there that was a really good deal its going to make your truck look great
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 11-19-2009, 08:41 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
I recently had the 73-87 version installed on my 77 Cheyenne. I had a custom built weld in C-notch before and was concerned as well. After looking at the quality of the notch, and the bracing that goes with it I feel it is very strong.
If you are really concerned, weld it in rather than bolting it up.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-19-2009, 02:06 PM   #10
Wild83C10
Wild83C10's Avatar
I installed my bolt-in c-notch about 8-10 years ago and haven't had an issues.
turbo=
Old 11-19-2009, 03:15 PM   #11
SCOTI
SCOTI's Avatar
Or.... bolt it in & then stitch weld around the perimeter of the c-notch bracket.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-20-2009, 01:56 AM   #12
c10seconds
c10seconds's Avatar
Thanks for the advice guys..Took the bed off today and I start the install tomorrow.
