Are 250 engine stands different than SBC stands?
I'm checking out pics of SBC stands and they look the same as mine but I want to be sure.
I think I just scored a 400/400 combo. ![]() |
Re: Are 250 engine stands different than SBC stands?
Every engine stand I've used is fully adjustable for any engine out there...
1970 C20 LWB Fleetside with a 472 Caddy engine! TH400 Restoration in progress 07 Yamaha 650 V-Star Custom 83 Honda V-45 Magna |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
If I am correct, the small I6 and small block perches are the same, the perches for the 292's are way different and then there are also BB.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Resident Curmudgeon
![]() Join Date: Dec 1999
If you mean the frame to engine mount towers, then they are different. Of course I have a vested interest in say so because I have 2 sets for sale on the parts board.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
2 yes and 1/2 no by the guy trying to make a buck.....
Nah, your ad was the reason I am asking. I wanted to make sure before I bought any. |
While they're different, you can still bolt a v8 to them.
Resident Curmudgeon
Actually I think Powerpro was thinking of an engine stand like what they sell at Harbor freight, etc. So it's 1 to .5
The I-6 stands are definitely different. Where they bolt up to the frame is different so that they are more rearward. A V-8 will bolt up but it will be closer to the fire wall.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Big Red - Now its a SWB!
the I6 stands are definately different they sit in the rear set of holes like mentioned above. However they are great if you want to swap from a v6 to a small block without changing driveshaft, moving the trans, etc. That's what I did in mine.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
#10 | |
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
