Old 11-18-2009, 05:48 PM   #1
leadsled
bad cab mounts on the frame help!
Can i buy new cab mounts for my frame or do i try to make new ones?
leadsled is offline   Reply With Quote
Old 11-18-2009, 06:03 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: bad cab mounts on the frame help!
You can make some, you can also buy some from guys here that will cut the rivets off of a parts truck they have and send them to you. LilRed might be able to help
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-18-2009, 06:10 PM   #3
navysnipe
navysnipe's Avatar
Yeah, Brothers has them you can buy them in pairs, and get only the ones you need. They became available after I called around and got a set out a boneyard in California.
Navysnipe
navysnipe is offline   Reply With Quote
Old 11-18-2009, 07:04 PM   #4
leadsled
are the mounts the same as the 67's
Old 11-19-2009, 01:43 AM   #5
Captainfab
60-66 Nut
Which mounts are you referring to, front or back, and what year of truck has the bad mounts? The rear mounts on a '67 are different than the rears on a '63-'66. I'm not sure about the fronts, I'd have to check.
Old 11-19-2009, 02:28 AM   #6
LILRED66
LILRED66's Avatar
Are you talking about the frame perches? Cab-to-frame mounts? Cab supports? Front or rear? 1/2 ton or 3/4 ton?
All of these things make a difference in what is available aftermarket or used.
I know where you can get all of the above, in good, used condition, so let me know if you are interested.
Good luck with your project.
LILRED66 is offline   Reply With Quote
Old 11-19-2009, 07:06 AM   #7
G-REX
Try parker Metal Products near PittsburghPa. Actually in Tarentum off of Rt 366,bought alot of sheetmetal there and they will bend you anything .I don't know if they ship.
G-REX is offline   Reply With Quote
Old 11-19-2009, 03:01 PM   #8
leadsled
the truck i have is a 66 c10 and all the cab mounts that are riveted to the frame are bad. what do i do
Old 11-19-2009, 03:18 PM   #9
SCOTI
SCOTI's Avatar
Rears are different (6x-66's are higher vs. 67-72's); the fronts are close enough to swap but the spacing on the rivet holes is different for the side of the frame.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-19-2009, 03:42 PM   #10
G-REX
Again Parker Metal sells a universal frame to body mount with bushings included,used them on other s before,just nee to fab alittle.If you need the number,let me know.
Old 11-20-2009, 01:00 AM   #11
Captainfab
60-66 Nut
Are just the tops bad.....where the mounts set? If so then If you can't find some good used oned to replace them, then just replace the top part. Do you have a way to weld? Most any welding/fabrication shop should be able to make the pieces for you (I know I could) as long as you provide them with either dimensions or patterns. Once you have your new pieces, cut out the bad part, and weld in the new pieces
