Looking for Header Recommendations
Hello everyone I have a 1970 C-10 Stepside 2wd with a GM Performance 350 crate engine. It's the basic street engine with cast iron heads. I need to replace my headers as they are completely burned out. I'm looking for a good sturdy set of headers that offer good clearance for the spark plugs. I'm just looking for the basic steel as I'm on a budget. Summit Racing has a large selection but I'd like to hear from experienced users before choosing. Thank you in advance for any advice you can give.
Re: Looking for Header Recommendations
Here is what I have been running on my 70 since around 1991...they look like **** but still no problems..seems like one plug on the passenger side is a bit of a problem to remove.. but nothing serious..hope this helps...Hookers
im running the cheap flowtech headers.. bought them for my big block for $167.. havent had any problems with them
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
check ebay for seller holleyperformance. I bought a set of ceramic coated hooker headers for my ls1 for $160 they are $390 from summit.
I've run Dynomax ceramic,Hooker,Blackjack and in my `70 C20 2WD small block I have a set of Summit 1 5/8 headers. It didn't seem to matter which set I've owned over the years they all have at least 1 plug that is tight. The Summit headers I have now makes #4 a bear to change(open end wrench)Will probably burn that boot over time. Spend the extra cash and get a good set of gaskets....The copper held up the best for me.
Thanks for all the helpful information guys! blazerboy72 I checked out that ebay site and you're right. There are some good deals on there.
70 Chevrolet=Obsession
Been running Hedman Headers for awhile and have had pretty good luck with them. Don't seem to present a great problem when changing plugs with a deep set socket.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
