Old 11-18-2009, 11:27 PM   #1
67chevemall
67chevemall's Avatar
My Air Bag Install Mar. 2008
Well here is my write up for rear air bags in a 67 Chevy:
Meant to say March 2009........ooops
First I went shopping:
Slam Spec. The pic shows their kit. Front kit is shown too.......
Don't need the pipe unless you gettn crazy or need "cups" and c notch
$ tossed invoice can't remember slam costs
Then the Local Fastenall
Bolts you need :
All 3/8's grade 8
2 - 4 1/2" bolts
4 - 1 1/2" bolts
6 - washers
6 - lock washer
$10
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 11-18-2009, 11:31 PM   #2
67chevemall
Re: My Air Bag Install Mar. 2008
AirRideFittings.com 4 1/8" NPT Schrader Valves
4 1/4" to 1/8" reducer bushing
4 3/8" OD to 1/4" NPT Female Connector
$37.00
Then I took my bed off but you dont have to.
Support the truck and get the jacks out to take out the springs, and a chain for safety, wrapped around the springs doesnt hurt anything.
Old 11-18-2009, 11:36 PM   #3
67chevemall
I started on the bottom by sizeing up the plate and cleaning up the frame for the welds.
Off to the local nut and bolt supply. Be prepared to have to buy a bag of 10 or 20
Bolts are 4 1/2" -16 3/8 grade 8
The bolt holds the plate nice untill it is welded with the help of a nut.
You can drill out the other two holes in the frame and use one long bolt and 2 small bolts if you are really haulin.
I am lazy so one is good for me until it breaks or I crash because of it. Then I'll use 3 bolts.
Old 11-18-2009, 11:40 PM   #4
67chevemall
Few more pics of the bottom
Old 11-18-2009, 11:47 PM   #5
67chevemall
The top is a little more work but not so bad:
Clean it all up for the welds with a grinder
mark the holes to be cut with soap stone/sharpie
Take your time to center it all nice. Use the plate
for your template and just soap stone it when lined up
Old 11-18-2009, 11:52 PM   #6
67chevemall
Rent a plasma cutter from local rental joint.
Cut no blast out the holes. You might want to take your fuel and brake line outta the frame.....
If it is your first time get some scrap and go fn crazy they rule!!
Be prepared to have a good dremel bit to bore it a bit and clean it up nice nice.
Old 11-18-2009, 11:58 PM   #7
67chevemall
I drilled a hole in the center of the disc plate so I could finger the holes and make sure they are perfectly in line, and to hold the sucker nice and tight while I welded it. I'm sure you could use clamps of some sort or the other holes.
Weld it up. Measure a hundred times both when you mark out the plasma cut and when you weld the plate.
The bolts you will need to buy is 1 1/2" 3/8's grade 8 bolts.
Old 11-19-2009, 12:03 AM   #8
67chevemall
Few more pics of the top go...
Old 11-19-2009, 12:14 AM   #9
67chevemall
Install your connectors into the bags.
Bolt the bag up to the top, then the bottom. Jack helps line er up.
Be sure to use blue lock tight on all the bolts.
Be sure to use lots of good rust paint and clean the frame.
Run the air line to the connectors in the bags and run the line to the glove box or anyplace for air fill spot.
Drove it all summer with no issues.
I have found 25-30psi is a nice ride height. 120psi and the rear goes up a good 10" for jumpn sand dunes......r wait thats the 500. head trama sucks
Fronts are up next after Christmas and New Years recovery.
Old 11-19-2009, 12:20 AM   #10
67chevemall
Well sure a few more pics......gave up the beer so I got some time on my hands... lol.............
Couple other projects done at the same time.
Old 11-19-2009, 01:57 AM   #11
OARNGESI
OARNGESI's Avatar
Watching
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 11-19-2009, 12:54 PM   #12
MAK191
Nice simple writeup with pics. Are you using RE7's on front and rear?
MAK191 is offline   Reply With Quote
Old 11-19-2009, 02:25 PM   #13
67chevemall
Yes RE7's front and rear
Fit great even when jacked to the moon.
Old 11-19-2009, 04:03 PM   #14
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice install!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-19-2009, 04:25 PM   #15
lts70
1970 Daily Driver
lts70's Avatar
Are the plates always used in the rear?
Did you get your stuff from Suicidedoors?
How high above stock are you when fully aired up?
Nice Job!
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 11-20-2009, 03:55 AM   #16
CUSTOM_1O
HaV0KSR559<~~~
CUSTOM_1O's Avatar
niceeeee now would u have to relocate them air bags if u wanted it to lay frame or could you just notch it while there n place of the old coils bekuz i want to bag it just not lay frame yet but eventually i would like to but i want to run the setup u have now too but not of id have to completly relocate the bags
...1969_CUSTOM_1O
FLEETSIDE_LONGBED
V8_THREE-FIFTY
[COMPLETE-EDELBROCK]
[PERFORMANCE-SERIES]
[CAM_CARB_MANIFOLD]
...TURBO-400_TRANNY...
CUSTOM_1O is offline   Reply With Quote
Old 11-20-2009, 01:26 PM   #17
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice write up...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-20-2009, 04:21 PM   #18
foosed
foosed's Avatar
Do you have any before/after comparison pics with the bed on? Looks great and cheap too. Hmmm Christmas is just around the corner....
1970 c/10 swb (show truck)
1972 custom/10 deluxe 4x4 (restoration pending)
2011 silverado ecsb z71 (daily driver)
foosed is offline   Reply With Quote
Old 11-20-2009, 04:48 PM   #19
67chevemall
He is one how it sits now. The bed needs another rubber spacer up front to make it level. The bed will go down more in the rear. The fender sits flush with the tire. But until the front is done it looks silly.
I should have a pic at home from before with the coils
Old 11-20-2009, 04:55 PM   #20
67chevemall
c notch you would remove the rivets and braket and bump stop.
weld in the c notch.
The bags sit from 2.5" to 11" in hieght
If you want to lay the frame it is all different.
Old 11-20-2009, 05:07 PM   #21
foosed
foosed's Avatar
that looks great. I cant quite tell from the pics how much clearance do you have from the frame when you air it out?
Old 12-22-2009, 09:13 PM   #22
nds1968
nds1968's Avatar
With your bags inflated to ride height how close is your axle to your fame with no C-notch? How much suspension travel does that give you? Thanks Nate
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 12-23-2009, 07:24 AM   #23
Rich48
Hi, About to do my 68 with Slam bags but have not bought a kit. I was going to bolt the bags to the trailing arms without the plate shown in the kit also the top mounting of the bags directly to the frame,again without the plate or do these plates help spread the load more? What do you think?
Cheers Rich
Rich48 is offline   Reply With Quote
Old 02-24-2010, 04:29 AM   #24
67chevemall
Ya I would use the plates. And a rear sway bar is good too.
With no air in the bag the axle sits on the bumper. It only takes 10psi to give me a good 3-4" and 20psi I would have to go measure the distance.
Old 02-24-2010, 04:38 AM   #25
67chevemall
Well I started the front air bags today.
First I took off the lower shock mount bolt. Wrapped a chain around the spring and losened the lower ball joint nut. Now I'm just waiting for the ball joint seperator tool.
I assembled the front air bags like in this pic.
Sorry my camera is down right now so I borrowed this pic..
So far I needed
8 nuts bolts washer and lock washer to mount the plates. with lock tight
4 bolts washer and lock w to mount the bag 2 on top and 2 on bottom.
Installed the air line fitting into the bag.
Tomorrow off to get a ball joint seperator and some high end 3/8 drill bits.
And Air line as SD didn't supple enough.
And dont let your bags sit a while with the orange sticker on them. What a PITA to
get all the sh!ty sticker crap off the bag.
