Old 11-19-2009, 01:50 AM   #1
dan42
dan42's Avatar
source for carb linkage parts?
Anyone know where I can get the proper linkage for a quadrajet that has the kickdown for a TH400? The P.O. rigged this one up, but unless I'm not looking at it properly, it's got the wrong linkage on it, and the kickdown isn't engaging. (Or is the linkage improperly installed??) I've got another Q-jet to put on it (this one's pretty trashed) but I don't have the proper linkage. Any help would be greatly appreciated.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 11-19-2009, 01:56 AM   #2
69lemans
Re: source for carb linkage parts?
Turbo 400 should have an electric kickdown switch at the gas pedal
69lemans is offline   Reply With Quote
Old 11-19-2009, 11:08 AM   #3
Sinister
Between Trucks...
Sinister's Avatar
Some had the kickdown at the carb. Is that vacuum hose going to the booster? Looks like the throttle rod should be over the hose maybe. Are you getting WOT when the pedal is to the floor? You could take the easy way out and install the Lokar kickdown kit, or Edelbrock make a carb mounted micro switch.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 11-19-2009, 08:30 PM   #4
JimKshortstep4x4
You may want to try this site.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-19-2009, 09:01 PM   #5
fine69
fine69's Avatar
71-72 were gas pedal mounted kickdown under the dash.
Up until then there were carb mounted. Looks like you are missing the tab that actuates the kickdown.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
