11-19-2009, 01:13 PM | #1 |
rag joint replacement
Do these wear out much? what happens when they do?
11-19-2009, 01:23 PM | #2 |
Moderator
Re: rag joint replacement
The rubber deteriorates over time with exposure to heat, oil, etc. It can cause slop in your steering when it gets worn. I just rebuilt mine. Cheap and easy. Click on my build link for pics/description. I also replaced the input (steering) shaft seal, and output (pitman) shaft seal on the power steering box at the same time.
You can purchase a complete ragjoint if the splines are worn on your original for around $50, or just replace the rubber disc for around $10 with a rebuild kit from a parts store.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 11-19-2009 at 01:26 PM. |
11-19-2009, 03:57 PM | #3 | |
11-19-2009, 04:42 PM | #4 |
I used the parts store rebuild kit and it has lasted over 15 years. Not hard to do. Saves you some cash versus buying an all new joint.
