Old 11-19-2009, 01:35 PM   #1
coop34
Gas Tank Suggestions???
What gas tanks from other vehicles have you swapped into your trucks. I've found a lot of information on the blazer tanks, but are there any others that people have used?
coop34 is offline   Reply With Quote
Old 11-19-2009, 03:16 PM   #2
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
Re: Gas Tank Suggestions???
im using a tank from a 77 chevy van. its a little tight but tucks up nice behind the bumper.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 11-19-2009, 05:58 PM   #3
coop34
Thanks for the idea vasquez. How low does it hang? Can it bee seen from the rear?
Old 11-19-2009, 06:38 PM   #4
vasquezmrysvll
"the other guy"
ill try to post pics later. but put it this way, i dont have a rear bumper yet and i can still see the bottom 1/3 of the center section of my dif. also i have a 5'' drop in the rear.
Old 11-19-2009, 07:17 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
hey folks,
Im about to order a gas tank kit from lmc that includes tank straps sending unit lock ring gasket j bolts
is this everything I need minus filler and hard lines going to fuel pump?
and should I order suburban lines or should I just get autozone lines and bend em myself? (got alot of that already)
thanks!
John
1999 Toyota Tacoma 4x4
Old 11-20-2009, 04:11 PM   #6
AH619
AH619's Avatar
u used a cj7 jeep tank.got the cradle used from salvage yard and ordered new tank/sender.it all came to around $175.00 its only 15 gal but its also smaller and doesnt hang down as low. and i didnt have to cut my bed crossbrace for clearence.
72 2wd lwb cheyenne super youngest son.green/white
72 2wd lwb cheyenne super oldest son.green/white
71 4wd 3/4 cheyenne super frame off manderin
copper / white 4 inch lift. FINALLY DONE / SOLD
72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO
REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR
COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856
AH619 is offline   Reply With Quote
Old 11-20-2009, 04:54 PM   #7
dave brode
dave brode's Avatar
vas,
Is it thinner than the blazer tank, top to bottom? Did you happen to measure the width? My frame is apx 30" inside.
TIA
Dave
'71 C-10 medium bed. Pump gas 454" +.030", stock valved 049s, dana 60 w/410s. 12.25 at 108.
dave brode is offline   Reply With Quote
Old 11-20-2009, 05:03 PM   #8
vasquezmrysvll
"the other guy"
it is thinner than the blazer tank, side to side it fits perfectly between the frame rails. the cross member directly behind the diff will need to be squared up(they are slanted from the factory) and the bottom edge of that same cross-member will need to be trimmed off. the rear most crossmember will need to be slid to the rear most end of the frame rails and bolted into place. when i got my from the local yard i grabbed the straps too, they will work just fine.
Old 11-20-2009, 05:07 PM   #9
dave brode
dave brode's Avatar
Thanks, do you happen to know what it measures front to back? My truck is back-halved and there are two 2x3 crossmembers behind the axle. I could move the front one forward if need be.
Thanks again for your reply.
Dave
Old 11-20-2009, 05:26 PM   #10
vasquezmrysvll
"the other guy"
Old 11-20-2009, 05:28 PM   #11
vasquezmrysvll
"the other guy"
about 25.5''
Old 11-20-2009, 05:31 PM   #12
dave brode
dave brode's Avatar
Thanks very much
Dave
Old 11-20-2009, 05:42 PM   #13
vasquezmrysvll
"the other guy"
Old 11-20-2009, 06:15 PM   #14
coop34
Hey AH, what year CJ did you get the tank from? Was it a difficult install?
Thanks for the pics Vasquez!
