Old 11-19-2009, 08:18 PM   #1
degree01
78 chevy rear end on a 66 C10
Can someone tell if it's possible to remove my original 6lug rear end on my 66 Chevy C10 and replace with a 5 lug 78 Chevy truck rer end or will it be too much hassle? I’m wondering if I could just take one off and replace with the other or am I Biting more then I can chew?
Thank you all in advance for your replies.
degree01 is offline   Reply With Quote
Old 11-19-2009, 10:11 PM   #2
47guy
Re: 78 chevy rear end on a 66 C10
http://www.classicperform.com/6092chevtrk.htm scroll down to Rear End Conversion Kits
47guy is offline   Reply With Quote
Old 11-19-2009, 10:29 PM   #3
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
You can swap the rear ends, just fine and easy, One thang to take in mind is the 71-87 rear is a little wider then the 63-69's. I believe it is 1.5" per side. You will have to get the correct backspacing rims.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 11-19-2009, 10:30 PM   #4
SCOTI
SCOTI's Avatar
The 78 rear is wider (about .750" each side) vs. a 66 housing; be aware it can impact the fit related to the bedsides if the truck is lowered.
The 78 also has leafs. If your truck has coils, you'll need the swap saddles onto the housing for the truck arms. If your truck has leafs already, you need to measure the distance between the center-line of the spring perches. If they're the same from both housings, you can just swap it. If not, you'll need to relocate the perches.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-20-2009, 01:33 AM   #5
Captainfab
60-66 Nut
When converting to the later model 12 bolt, you will need to accomodate the panhard bar also. This would be easiest by locating the bracket and panhard bar from a '63 or '64 differential since it welds to the passenger side axle tube. You could also fabricate your own of that same style. I believe there is also an aftermarket kit (CPP?) for lowered trucks that mounts the panhard bar to bracket bolted to the passenger side trailing arm.
Old 11-20-2009, 01:36 AM   #6
SCOTI
SCOTI's Avatar
I would definitely go aftermarket for the Panhard bar. ECE & CPP offer kits.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-20-2009, 11:55 AM   #7
degree01
Ok thank you all for your replies I think i might just keep the same and just convert to 5 lugs, seems easier.
thanks again
Old 11-20-2009, 02:16 PM   #8
SCOTI
SCOTI's Avatar
thanks again
If there's nothing wrong w/the current rear, swapping new axles is definitely the better way to go. Replacement axles will have 44yrs less wear & are typically 30% stronger.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-20-2009, 02:32 PM   #9
degree01
Hey Scoti, if i replace the axels’, do i have to do some kind of special machine work to it? i heard that if you replace the axel you have to take it somewhere where they get a magnet and align it or something like that, that would seem to be the easiest way to me, but I don’t know much about rear ends so i didn't know what they were talking about that is why i was trying to go a different route.
Old 11-20-2009, 03:54 PM   #10
SCOTI
SCOTI's Avatar
No 'special' machine work; just standard R&R of the axles. You'll need the new axles & possibly spider gears as new axles come 30-spline & some of these trucks had their parts swapped (you might possibly have 17-spline). You'll also need a set of brake drums from a 71-72 truck.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-20-2009, 04:35 PM   #11
degree01
Thanks alot Scoti, that helps alot. does your truck have air bags?
Old 11-20-2009, 05:54 PM   #12
jjaction1
Here is a great article on swapping out rear brakes and changing from 6 lug to 5 lug rear axles, great pics to help guide you too.
http://www.customclassictrucks.com/t...rop/index.html
JEFF
My 1966 C10 build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=371688
For all you picture lovers:
http://s653.photobucket.com/albums/uu256/jjaction1/
jjaction1 is offline   Reply With Quote
Old 11-20-2009, 08:51 PM   #13
SCOTI
SCOTI's Avatar
Yes. Bags, blocks, bolt-in size/style c-notch, relocated shock brackets, & adj Panhard bar.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
