Old 11-19-2009, 08:19 PM   #1
rogergodding
rogergodding's Avatar
Strange issue
It seems that when I make a sharp left turn or change lanes quickly that I lose power, like it's outta gas or something.... don't think it is electrical but I could be wrong..... running an edelbrock 600..... any ideas?
rogergodding is offline   Reply With Quote
Old 11-19-2009, 08:31 PM   #2
mclairmo
Re: Strange issue
Check trans fluid level, that happens to me when the fluid is low. Really weird but true. Also, make sure the trans filter is still in there correctly. On my TH400, it came loose and may have contributed to the power loss issues I was having.
mclairmo is offline   Reply With Quote
Old 11-19-2009, 08:42 PM   #3
1-PU70
1-PU70's Avatar
Re: Strange issue
I would check the float level i n the carb.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 11-20-2009, 02:21 PM   #4
rogergodding
Re: Strange issue
I was thinking something with the carb.... don't remember it doing this before I installed the edelbrock...... haven't done much work on carbs other than installing or removing them.......... have adjusted the f/a mixture, that's about it....
Old 11-20-2009, 04:07 PM   #5
jaymc32
Re: Strange issue
Gotta be a carb issue cause mine started doin the same thing after I installed an Edelbrock 1405. Maybe the carb gurus can enlighten us as to why our Edelbrocks dont like goin left!!
I rebuilt mine prior to install and spent a lot of time making sure I had the floats set properly, so that wouldn't be my first thought, but it does seem a likely culprit.
jaymc32 is offline   Reply With Quote
Old 11-20-2009, 07:24 PM   #6
rogergodding
Re: Strange issue
Yeah, would like to know more.... mine is basically straight out of the box......
Old 11-20-2009, 08:07 PM   #7
k.t.
Re: Strange issue
My truck did that to me. It was my starter bolts backing out. It would let the starter swing over and ground out on the exaust pipe lossing power to the dizzy but would act like it was running out of gas. But only in a left hand turn. So check starter bolts.
k.t. is offline   Reply With Quote
Old 11-20-2009, 09:26 PM   #8
jaymc32
Re: Strange issue
Well, ran out an checked my starter, its tight. I still say carb cause it didn't do it when I had the Quad on it.
Old 11-21-2009, 08:42 PM   #9
rogergodding
Re: Strange issue
yeah, I just installed a new high torque mini and it's tight...... was doing this before new starter as well....
Old 11-21-2009, 10:02 PM   #10
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Strange issue
Sounds to me like your float bowl level is too low and the engine is starving out on left turns.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 11-21-2009, 10:16 PM   #11
jaymc32
Re: Strange issue
Made a landfill run today, so paid particular attention to this issue. Seems to happen only in light throttle conditions. If I idle into a left turn it all but dies, but if I'm into the throttle a third or half it runs fine. So whatever it is seems to only be affecting my idle circuit. Roger, you stated that lane changes affected yours, not so in my case.
Old 11-21-2009, 11:03 PM   #12
rogergodding
Re: Strange issue
it was a "hard" lane change though, If you drive around DFW, you know what I mean The only time it has done that "changing lanes" on the way home before I posted this.... it almost died altogether.....
