Old 11-19-2009, 08:30 PM   #1
americanmusc1e
americanmusc1e's Avatar
Pictures of the Carnage
on the way to college yesterday I blew my rear end up.
here's the info
http://67-72chevytrucks.com/vboard/s...d.php?t=372529
I pulled the diff cover off right after the symptoms started and I didn't see anything suspicious, (I was just changing the fluid and checking the gears, I thought the noises it was making were coming from somewhere else)
these are the lager pieces that came out when I pulled the diff cover, there were tons of metal pieces
so now I've got to get another rear
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 11-19-2009, 08:33 PM   #2
mclairmo
Re: Pictures of the Carnage
That sucks.
mclairmo is offline   Reply With Quote
Old 11-19-2009, 08:34 PM   #3
big_al_71
big_al_71's Avatar
damn!!!! that left a mark...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-19-2009, 08:47 PM   #4
americanmusc1e
yeah, there were nasty marks on the diff cover from it coming apart!!!
anybody want to give a guess on what happened to it?????? too many one-wheeled burnouts????
-- Josh
Old 11-19-2009, 08:59 PM   #5
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
if it helps your the second one Ive seen in 3 months the other one looks the same way ..the spring pin that holds the spider gear shaft broke then it was just a matter of time before it falls HALFWAY out tears up the rear cover for a second before the shaft hits the cast case ussually locking the wheels for a second until it breaks the pin off or you STOP...fast....
we reused the case and just dropped a cunk into it with a locker ..just be sure to check your backlash
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 11-19-2009, 09:10 PM   #6
Rob H.
Rob H.'s Avatar
I saw a truck break one when I was a kid in the late 70's or early 80's. He was going past the house, probably running 60. Sure was a heck of a skid, he ended up sideways in the road, we had to drag him into the yard with our Massey Fergason. I remember it had quite a pucker factor on that guy!
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline   Reply With Quote
Old 11-19-2009, 09:19 PM   #7
americanmusc1e
I guess I'm lucky that mine just broke, instead of locking up.
I was accelerating (rather slowly) from a stoplight and only going about 30mph when it happened. but I'm glad it broke so I could push it off the middle of the street.
-- Josh
Old 11-19-2009, 09:30 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'd just put another set of used spider gears and center pin in and keep on trucking.
Old 11-19-2009, 09:55 PM   #9
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Agreed. If nothing made it's way into the ring and pinion gear set, put another set of spiders and center pin in, keep driving for a while until you have time/money to put in another rear end.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-19-2009, 09:55 PM   #10
americanmusc1e
I've got another diff exactly the same off the '69 parts truck
but then I'll still have a weak 3.08 open diff
-- Josh
Old 11-19-2009, 10:06 PM   #11
WIDESIDE72
WIDESIDE72's Avatar
x2 Been there, done dat.
WIDESIDE72 is offline   Reply With Quote
Old 11-20-2009, 12:31 AM   #12
americanmusc1e
if my truck has factory 3.07 gears, do I have 30 spline axles????
-- Josh
Old 11-20-2009, 01:04 AM   #13
Pont406
It's a 30 splines. Looks like water mixed with gear oil to me. Was that rear submerge in water?
Pont406 is offline   Reply With Quote
Old 11-20-2009, 09:18 AM   #14
americanmusc1e
It could have been at one time, I live out in the country
-- Josh
