Old 11-19-2009, 09:19 PM   #1
sailed2japan
Jonny
sailed2japan's Avatar
A couple questions about frames
What are the differences between a 1/2, 3/4 and 1 ton frame? I've been told that a 3/4 is the same as a 1/2 by on person and the same as a 1 ton by another. Just trying to get this right.
Also wondering if a suburban tank will fit behind the axle on a short bed?
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 11-19-2009, 09:23 PM   #2
b454rat
Re: A couple questions about frames
1/2 and 3/4 ton frames are the same, 1 ton are by themselves. 1 tons are thicker and aboot 2" taller. If you ever noticed a STOCK 1/2 and 1 ton next to each other, the 1 ton sits higher.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-19-2009, 09:36 PM   #3
sailed2japan
Jonny
Awesome, now I know I want a 1 ton frame if I rebuild my truck. I really want to put together a ccswb, though.
-AEC Hundley USNR
Old 11-21-2009, 10:18 AM   #4
Desert1957
Desert1957's Avatar
Guys,
I have see this question alot on this forum and I agree , but here is something to think about. I own two trucks. 87 1/2 and an 83 3/4 , when I measure the frame thickness on the 83 its between .040 and .050 thicker everywhere.
only difference is the 83 has the camper special option and a stick shift. I'm guessing the frame is beefier because of this. Every hole , bracket , and bend are the same on both frames.
Any input on this would be appreciated....
Desert
Desert1957 is offline   Reply With Quote
Old 11-21-2009, 10:55 AM   #5
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by Desert1957 View Post
Guys,
Desert
How thick is the steel of the two frames?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 11-22-2009, 07:56 PM   #6
Desert1957
Desert1957's Avatar
Here are the measurements , I checked both my trucks at the front radiator support , the trans crossmember area , and the rear frame by the shock mount.
87 1/2 - .165
83 3/4 - .235
same frame lenth, width , and all the same bends and mounting holes?
Any body have a clue why there is a difference?
As stated before the 3/4 has a "Camper Special" option, and is a Silverado , the 87 is a 1/2 "Custom Deluxe"
Desert
Old 11-22-2009, 10:50 PM   #7
TravisMartin
Curmudgeon of Poor Means
I've measured too; I find 3/4 ton frames are heavier than 1/2 ton frames. They look the same, but I'm pretty sure they aren't.
Travis
TravisMartin is offline   Reply With Quote
Old 11-23-2009, 03:13 PM   #8
68 TT
68 TT's Avatar
87 1/2 - .165
83 3/4 - .235
Desert
Thicker metal in the top & bottom flanges make the frame able to handle more load without bending. Structurally the sides are pretty much just place holders to keep the flanges in place and contributes a small amount to the bending strength of the frame, think I-beam. Boxing gives torsional strength and a small amount of bending strength.
Old 11-24-2009, 03:57 PM   #9
sailed2japan
Jonny
Awesome info guys I really appreciate it. I pulled this thread back up just in time. I have been trying to find a 1 ton chassis, but haven't had any luck. i was about to go out and just grab a 1/2 or 3/4. Now I'm staying away from the 1/2.
Who's got an extra frame laying around?
-AEC Hundley USNR
Old 11-24-2009, 04:22 PM   #10
sailed2japan
Jonny
I came up with another question. how would one go about putting a regular axle under a cab and chassis? Is it as simple as changing the spring hangars?
-AEC Hundley USNR
Old 11-24-2009, 07:27 PM   #11
TravisMartin
Got a rolling chassis but it's a single cab LWB; will that do you any good?
Old 11-24-2009, 08:12 PM   #12
sailed2japan
Jonny
Shot you a pm.
-AEC Hundley USNR
Old 11-24-2009, 09:41 PM   #13
KQQL IT
At the body shop.
KQQL IT's Avatar
I believe the spring hangers are the same. The Ubolts may be differnt tho
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
