Old 11-19-2009, 11:48 PM   #1
63deluxfleet
63deluxfleet's Avatar
6 lugz...iwant 5....but im on a bugdet
hello i was wondering is there a way to get an adapter for my 6 lug setup? i want to run some astro supremes and as you may know with my unemployment, the full suspension swap isnt coming anytime soon, so is there any way to do this and also what are the pros/cons if any? and also price range?
A girl phoned me the other day and said... Come on over, there's nobody home. I went over. Nobody was home. -Rodney Dangerfield
.......THE ROAD TO HELL IS PAVED WITH GOOD INTENTIONS.....
63deluxfleet is offline   Reply With Quote
Old 11-20-2009, 01:51 AM   #2
63deluxfleet
Re: 6 lugz...iwant 5....but im on a bugdet
well i guess im going to have to do it the expensive way then
Old 11-20-2009, 02:24 AM   #3
Captainfab
60-66 Nut
You might give these guys a call.
http://www.performancewheel.com/spac...egory=6&gacid=
BTW what did you have in mind for a suspension conversion that is "Expensive" ?
It can be done relatively inexpensively if you're resourceful and use OEM parts.
Old 11-20-2009, 02:38 AM   #4
Slow Build
Slow Build's Avatar
I know you'll want front disc brakes more sooner than later Isaac. Why buy wheels that are going to be the wrong backspacing for the setup you will eventually want.
Here is a good thread on the disc brake upgrade using junkyard parts. http://67-72chevytrucks.com/vboard/s...d.php?t=367260
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 11-20-2009, 02:40 AM   #5
63deluxfleet
well i know its not exactly expensive to change out my suspension to a 73-87, but im currently on unemployment and im going 2 fresno state so between the tution increase, and my insurances on both cars and drivin my truck (gass guzzler) i dont have much cash, but i would like a temporary fix. i have some astro supremes that my dad gave me with new tires so that cost me nothin, so basically im tryin to get the cost effective "equivalent" or close to.
Old 11-20-2009, 09:53 AM   #6
70 Suburban
Rods
It wasnt to bad. Parts were just about 200 from the junk yard for the front...took a day to swap. And thats with beer time.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 11-20-2009, 12:42 PM   #7
Roadhammer
Roadhammer's Avatar
Junk yard stuff will be the cheapest. I would thing swapping rear axles for 5 bolts and then steal a whole front crossmember/brake booster with disks setup. Thats what i did bought a cheap donor and stole EVERYTHING! LOL
The front end swap i soooo easy. I never did anything significantly mechanicall befoe and i had no issue doing the swap. Pwr steering box adapter from cap'n and your on your way.
I have 6 lugs in the back and want 5 cuz i have a set of 5 lug rallys. I went through all the costs of adapters vs. axle swap vs diffswap and if you can get a good diff from a junk yard thats the cheapest i could come up with.
Jory
Roadhammer is offline   Reply With Quote
Old 11-20-2009, 01:50 PM   #8
scotts62
One day...
scotts62's Avatar
If you need more parts other than the suspension stuff, try and find a cheap parts truck that might even run with a 350, who knows you might get a bunch more parts you need for a cheaper price.
Scott
93 crew cab build
Project 62
Old 11-20-2009, 04:55 PM   #9
spr85gmc
spr85gmc's Avatar
with a 72- 87 rear endbeing wider will a swap affect how low i can get my 66 i plan on getting mine as low as possible using a static drop may 7+ inches in the rear. can i do it on stock rallys with a descent sized tire?
spr85gmc is offline   Reply With Quote
Old 11-20-2009, 06:03 PM   #10
markeb01
Senior Enthusiast
markeb01's Avatar
Bummer, I actually had a pair of 6 lug to 5 lug adapter plates up until a few months ago when I just threw them in the garbage. More recently there was a free "shred day" and as I was going through old paperwork I even found the receipt for them! I think they were just shy of $100 for the pair.
I never even used them, I just carried one with the spare tire for the period when I had 5 lug discs in front and the original 6 lug rear end. I'm not a big fan of adapters for daily use, which is why I tossed them out. For those interested however these are still being manufactured by at least a couple of companies:
https://uswheeladapters.com/Home_Page.php
http://adaptitusa.com/
This 2nd link even lists the 6 to 5 adapter, but they don't have the correct picture posted.
Old 11-20-2009, 09:20 PM   #11
sailed2japan
Jonny
sailed2japan's Avatar
Have you read about how to swap on spindles and discs from a 88-98 6 lug truck?
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 11-20-2009, 10:34 PM   #12
SCOTI
SCOTI's Avatar
He wants 5-lug to run his Supremes. The standard 71-87 5-lug swap would be easier (if he had the finances to do the swap).
63deluxfleet,
Are you 100% sure the Supreme's are 5x5 pattern?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-21-2009, 03:17 AM   #13
63deluxfleet
yea they 5 on 5
