Old 11-20-2009, 09:15 AM   #1
cyberpine
cyberpine's Avatar
Converting to Manual windows
I'm looking to convert my 87 C10 to manual windows. The power windows and locks currently down't work.
I found these for about $45 for both but says it's for a V30. Will they fit my 87 C10?
Parts Geek for 87 v30 Manual Windows Regulators
They look exactly like these which say they will fit my truck.
Other Seller
How tough is it to do the conversion? Should I expect to have to do any drilling, cutting or grinding?
Will parts come apart easy if there is rust?
Also, I was planning to dye the plastic door panels black (from dark blue) anyways. Any suggestion on what I can fill plastic holes with?
Thanks.
JC (Cyberpine)
My 1987 C10 Short Bed (click on slideshow to see full album)
cyberpine is offline   Reply With Quote
Old 11-20-2009, 11:06 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Converting to Manual windows
they look like the right part and as gar as i know you can interchange doors from the larger trucks to the smaller ones..
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-20-2009, 11:38 AM   #3
Damien
Damien's Avatar
You will also need door panels and window cranks. You could probably cut a hole in the door panels you have now too, but it might not look very nice.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 11-22-2009, 09:26 AM   #4
HOGDADDY
HOGDADDY's Avatar
That does look like the right manual window piece to me also.
I am doing this same swap from power to manual door. The hardest part is removing the power hardware and glass. You have to remove dam near every bolt on door and loosen vent window since door glass rides in the channel.
The screws on top of vent window are a pain to break really need impact screwdriver.
It will finally come out through the large hole in door.
You will also need to cap off the hole left by the power wires in door and don't forget to swap out your lock.
Might also need new weatherstripping also old stuff is probably brittle.
HOGDADDY is offline   Reply With Quote
Old 11-22-2009, 10:39 AM   #5
68 TT
Still plays with trucks
68 TT's Avatar
That is a whole lot of work to do to convert them to manual windows & locks. Maybe we can diagnose your problem and make what you have work again.
What is wrong with your power windows & locks? Neither one functions? Does one side work and not the other?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 11-22-2009, 05:59 PM   #6
LONGHAIR
The window regulators and locks are totally seperate systems, neither sharing anything but "Power"....I would look there first. It may be easier to repair what you have than to get into all of the swapping.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 11-22-2009, 06:27 PM   #7
cableguy0
if neither work im with longhair. i would bet its a simple wiring issue. a broken wire or bad ground etc. its highly unlikely for 2 window motors and 2 lock selenoids to be bad all at once. the parts to basically rebuild the electric setup would probably still be cheaper than trying to convert it over and going through the hassle and headache of working with door glass in a confined space. the first thing to do is check and make sure you dont have a blown fuse. then check for broken wires. the place where the wires comes from the cab into the door is the first place i would look. theres also a ground connector as well
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-23-2009, 11:49 PM   #8
85 c-10
I dont want to highjack this thread, but what can be done to make power windows run faster? I put new regulators in both doors, and the drivers window still wont work and the pass. side barely works. It takes a lot of pushing/pulling by hand to go. They are geting power b/c I can hear them groan for a sec. and my headlights dim ever so slightly when I hit the switch. I was going to look for a set of manual doors and cut the whole inner door out and weld into mine. Is there a better way?
Josh
85 c-10 is offline   Reply With Quote
Old 11-23-2009, 11:59 PM   #9
Scootin 81 C20
3/4 Ton Rodder
Scootin 81 C20's Avatar
I can think of an easier solution for switching to manual windows and locks...................change the doors to earlier, non-power ones.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD
1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy.
Scootin 81 C20 is offline   Reply With Quote
Old 11-24-2009, 12:15 PM   #10
68 TT
68 TT's Avatar
Josh
The 77 truck power window door I pulled some parts from had all of the rollers rusted solid and the grease in the tracks was petrified. I bet you have the same problem. Add some functional rollers and clean/grease the tracks and it should work as good as new.
Old 11-24-2009, 12:43 PM   #11
flamingbig10
6.0 powered square
flamingbig10's Avatar
I did the swap, it was well worth it
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 11-24-2009, 04:37 PM   #12
cableguy0
a little cleaning and grease in the roller and tracks and regulator makes all the difference in the world. also check the wiring. dimming the lights means its drawing hard on the electrical system so the motor is struggling.
Old 10-02-2010, 11:39 AM   #13
cyberpine
cyberpine's Avatar
At a high level what where your steps? Did you have to pull out your glass window? Big deal to remove motor? insert manual regulator? Got any pics?
Thanks.
JC (Cyberpine)
