Old 11-20-2009, 12:57 PM   #1
shaneschevys
Its always something!
shaneschevys's Avatar
5.3 guys I need a little help!
What all is involved in taking the plastic intake off of a 2000 5.3. I have never worked on one of these engines. I am having to replace the camshaft sensor & the guys cousin broke it. So the only way I can see to get to it is to remove the plastic plenum/intake. I'm just wandering what I am about to get into.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 11-20-2009, 03:12 PM   #2
Ackattack
Ackattack's Avatar
Re: 5.3 guys I need a little help!
disconnect the fuel lines from the fuel rail, unplug the injectors (or move the fuel rail out of the way)
disconnect the TB
remove about 8 - 10 bolts.
There is no water in the intake.
I thought the camshaft position sensor was on the back of the block, and accessible without taking the manifold off (oh.....I guess if it's on an engine stand)
GL
Ackattack is offline   Reply With Quote
Old 11-20-2009, 03:19 PM   #3
Hart_Rod
Hart_Rod's Avatar
It's pretty straightforward as Ack says. The "dry" system the LS motors are built on make it pretty simple and "clean".
R/
Hart_Rod is offline   Reply With Quote
Old 11-20-2009, 05:58 PM   #4
shaneschevys
Thanks guys! It was real simple to work on. I was just a little nervous because it was something new.
79 p10 stepvan
72 Short Fleetside
72 Suburban
64 Short Fleetside
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Old 11-20-2009, 08:06 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Dude, you putting in an LS? Sweet! Me too, but in a 65
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
