11-20-2009, 03:58 PM | #1 |
Drop Spindles vs Drop springs
I want to convert my 68 to 5 lug and I have donor truck thats 5lug and should I just use the spindles thats on my donor truck and buy drop springs or should I just buy drop spindles? I am looking to go 2 1/2 in the front and 4 in the rear just not sure what would be my best bet Thanks Brandon
Brandon |
11-20-2009, 04:04 PM | #2 |
Tot Roddin'
Re: Drop Spindles vs Drop springs
Brandon, I would recommend the drop spindles because in my opinion anything over a 2" front drop spring will affect the front suspensions geometry. Just my opinion....
I know the spindles will cost you more, but in the end it will be worth it. Besides, after you get to 2.5/4 you will always want to go lower and then you'll need spindles anyway. I'd highly recommend checking with ECE (Early Classic Enterprises) as they are one of the best companies on the market today for products for the 63-72 suspensions. www.earlyclassic.com
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 11-20-2009 at 04:05 PM. |
11-20-2009, 04:25 PM | #3 |
I second the purchase of drop spindles. THen if you decide to go lower a quick spring change and you are ready to go.
I got my drop spindles from Nate at Porterbilt. THey were McGaughy drop spindles and less then 240 shipped to my door. They also use the OEM year steering components as I purchased new Moog steering stuff and they mounted right up |
11-20-2009, 08:51 PM | #4 |
ok guys thanks for the help I guess I need to do some shopping
Brandon |
11-20-2009, 09:54 PM | #5 |
Also with drop spindles you wont have to get shorter shocks
70 SWB STEPSIDE 70 BLAZER 09 challenger |
11-20-2009, 10:00 PM | #6 | |
I'm not as good as I once was, But I'm as good once as I ever was. |
11-21-2009, 12:16 AM | #7 |
70 Chevrolet=Obsession
As long as you're gonna switch to 5 lug, why not get some drop spindles for a 71-72 and convert to disk brakes at the same time?
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
11-21-2009, 12:22 AM | #8 |
wasnt that his plan
11-21-2009, 03:58 AM | #9 |
Just a thought but in most cases a 15in wheel wont work with a spindle you need a 17 or bigger. Just something to think about, that will also raise the cost of your project
11-21-2009, 08:09 AM | #10 | |
Watch out for your cornhole !
Flat wrong. 15 inch wheels work fine with drop spindles. The only issue can be if he chooses 3 inch drop spindles, they require slight clearancing of the control arms if the back space is too great. I've lost count of how many trucks I've owned with drop spindles and 15 inch wheels.
11-21-2009, 08:52 AM | #11 |
67-72 parts collector,…
That might be true on some of the '99-up trucks,... but it's not the case with any spindle made for the trucks from '63-'98.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-21-2009 at 08:53 AM. |
11-21-2009, 11:09 PM | #12 |
Whats the best company to deal with for the spindles or does anyone have any for sale I am also looking for 4" drop in the back
Brandon |
11-21-2009, 11:15 PM | #13 |
Hands down,... ECE. (Early Classic Enterprises).
11-22-2009, 07:41 AM | #14 |
Yep, ECE is your place.
11-23-2009, 09:43 AM | #15 | |
Tot Roddin'
Just continuing what Keith and Kevin each stated... ECE all the way!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-02-2009, 02:17 AM | #16 | |
Long live SLIM ------------------ At least try to buy American |
