whats the cheapest but good way to drop the front of my 67 c10
i want to drop my truck so does anyone know a good way to drop the front end thats not to much money, ive already got the rear end done
![]() Join Date: Mar 2008
Re: whats the cheapest but good way to drop the front of my 67 c10
How much you wanna drop it? You could cut a turn off a coil, that would be good for about 3 inches I believe. Or buy drop spring. After that you gotta buy spindles and springs. Or, you could Z the frame 3inches. That would be free if you do it yourself.
A 3 inch springs like 90 thru summit
70 SWB STEPSIDE 70 BLAZER 09 challenger |
cut one coil off
chrome makes it go FASTER!
Free is cheapest.
Here's my '71 with 1 1/4 coil cut off. dropped about 3 inches. I cut the springs with a grinder.
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
cut the coil spring with a cut-off tool ... NOT a torch ... procede to ride low
yeah you can lower it for cheap why bother with replacing 40year old balljoints or tyrod ends or other old stuff while you're got it apart
70 Chevrolet=Obsession
If you want your tires to wear right, use drop spindles. Cutting springs just messes up your camber.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
Cutting springs does not mess up camber any more than dropped springs do.
![]() Get your front-end aligned afterward and you'll be fine. |
That's true, but either cutting or buying drop springs messes up your camber unless you DO get an alignment. That's all I was saying. I might add that shortening the springs by either method reduces vertical wheel travel whereas using drop spindles does not which makes them preferable.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) Last edited by unclewatts; 11-23-2009 at 01:28 AM. |
ENGINE BUILDER
I cut one and a half coils off the front springs on my truck and it rides on the snubbers. You should at least check your toe in. I bought some circle track toe in plates off EBAY they work great and they are cheap! My pal bought a caster camber gauge from Speedway Motors and I set my camber to zero or slightly negative and then adjusted the caster to make the truck drive straight with no hands on the steering wheel. WORKS GREAT!
JIM ZAG Last edited by jim zag; 11-23-2009 at 10:35 PM. |
Shorter springs has nothing to do with wheel travel either. <sigh>
#13 |
Redefining LowBudget
Really tell me how that works??..I can understand drop spindles and that statement but short springs = less travel.....
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#14 |
Shorter springs only locate the spindle further UP the arc of a-arm travel.
The spindle can still move the same amount, it's just the "starting point" of the range of motion has moved. Last edited by Shane; 11-23-2009 at 04:30 PM. |
#15 |
ok but travel down may result is a lost spring......I have heard of guy having springs pop out of the pocket if they cut to much off
#16 |
You will not lose a spring if only a single round is cut. I promise.
