Ebrake question for rear disc conversion..?
What does everyone do for an ebrake if using chev calipers? I tried to track down a set of caddy ones but got the wrong ones ordered twice. I heard about a transfer case brake of sorts but i cant find any info about it. Help?
JP 70 K20 74 CJ5 |
Re: Ebrake question for rear disc conversion..?
Carry a brick shove it under a wheel when you park.Unless you got a stick i wouldn't be too worried about it i can't remember the last time i used my e brake ain't even sure it works.
Its a Truck Thing......
What chevy calipers are you using?
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
![]() Join Date: Oct 2008
I think a lot of people use Cadillac seville rear discs that have an ebrake that'll work. I don't remember the years.
#6 | |
JP 70 K20 74 CJ5 |
#7 | |
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
The parking pin in the tranny.
But you could use a line lock!
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
You lower your truck enough to lay frame and when you park all you do is air it out..... frame on ground = parking brake.
![]() ![]() Last edited by Pipeworx; 11-22-2009 at 12:55 AM. |
a line loc would be the easiest
Wouldn't a line lock suck the battery down if its left on for a day or two?
#12 | |
The whole point of an actul functional "Emergency" brake is that it does NOT rely on the hydraulic system...so it stiil works in the event of a hydraulic failure. That is why they are usually cable operated.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#13 | |
Others, usually those never having been in a situation requiring the use of said EMERGENCY braking, won't get it until they experience the need first hand. I've never experienced it on a disc brake eqipped vehicle; but when I was younger, my 69 Camaro & my 64 truck both had hydraulic failures & thus no brake pedal @ all.
#14 | |
Oh, I know what you are saying SCOTI, but even with dual reservoir master cylinders and proportioning valves that block off the failed end...those first few "panic pumps" and losing half of your braking power? You may get it stopped before you hit something or someone? maybe not?
One would hope that with "automotive enthusiasts" the maintenence of the braking system would prevent hydraulic failures, but that is why they call it "Emergency", you just never know.
#15 |
GM ONLY BABY!!!
My line loc only holds for 30 seconds during the burnout. At least that's what the instructions said. I've never done a 30 sec. + burnout.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
#16 |
We used a hydraulic lineloc (you can get them designed for park brakes) on one of our tow trucks, it only uses power to block the line then the pressure holds it, out truck was only used once a month or so and it never drained the battery
#17 |
This works great for parking on hills so you dont have to wory about your tranny keeping it stoped http://secure.chassisshop.com/partdetail/875/
but as for an emergancy as in hydraulic failure Im with PIPEWORX let the air out! |
#18 |
![]() Join Date: Nov 2007
#19 |
I believe it is 79 Eldorado rear calipers that are the direct bolt with E brake match for the truck fronts. At that is what is suggested for the brackets I have been looking at for my Dana 60 8 lug.
#20 |
Ive seen people use the motorcycle rotor on the rearend yoke and use the moto brake lever that locks closed with a pin. that still uses hydraulic but its a different line.
Theres also other street rod kits that use the same type system. |
#21 | |
Boss Hogg
![]() Join Date: Apr 2002
![]() Although it would be useless in one instance, and this has happened to me once in my '76 4x4, the driveline failed/grenaded. But what are the chances of both a hydraulic and a driveline failure at the same time? ![]() |
#22 |
I wish I could say that pic was of my tcase, but it's directly off the HAD website. I'll likely be doing this though.
#23 |
Here is your source for calipers http://www.tsmmfg.com/3121.htm
They have both the large and smaller (metric) parking brake calipers. For those yet to do this swap they have the brackets if you don't care to build your own. They have e-brake extensions to reuse the stock cables. I've also seen cables from CPP. Jason |
#24 |
Still plays with trucks
The application for the calipers with integral e-brake is 76 to 78 Eldorado only. 12" diameter 1.25" thick rear rotors with a 5 on 5 bolt pattern.
For 8-lug use the truck 1.25" front rotors. For 5 on 4-3/4 bolt pattern use C3 Corvette 11.75"x1.25" front or rear rotors.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#25 |
The C3 Vette (65 to 82) has both power and manual brake versions of the master cylinder with different piston bores so if you are running manual 4-wheel disc you can get the right MC so they work right from that application.
With power brakes you can also use the 76 to 78 Eldorado MC and prop valve and have enough fluid volume for four large piston calipers. The C3 Vette was balanced well enough they did not use a prop valve on them.
