Old 11-21-2009, 11:22 AM   #1
NicoSlam
ralley wheel question
I currently have the ralley wheel with 4x4 centercaps on my 69' 6lug. I want to change the center caps to the corvette style but I'm not sure how they attach. do they also use the screws? If I change I know I'll need to get smaller lugs but will they work on my rims. thanks for everyones help
NicoSlam is offline   Reply With Quote
Old 11-21-2009, 12:08 PM   #2
big mike71
big mike71's Avatar
Re: ralley wheel question
I have the flat style caps and they snap on.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 11-21-2009, 12:25 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I didn't think that car rally caps would snap onto truck rally's. I don't think they have the little bumps in the center area like the car ones do.
The ones above are car rally's (aftermarket with correct lug pattern for the truck) which is why they work fine.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-21-2009, 12:31 PM   #4
Mayo
Cool Truck
Mayo's Avatar
Corvette caps just snap on. I don't believe they work on truck rallys, but I could be wrong.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 11-21-2009, 01:10 PM   #5
mclairmo
Car ralley caps will not work. You can only use caps that bolt on from the front or screw in from behind. I have late model 6 lug chromed plastic Chevy caps on mine that I screwed in from behind. They are much lower profile than the ones you have and look good. Much better for a lowered and/or 2wd truck.
mclairmo is offline   Reply With Quote
Old 11-21-2009, 01:30 PM   #6
SCOTI
SCOTI's Avatar
They don't bolt-on but they can. A guy I used to work with fabbed a bracket that used the 3 holes that secured the OE caps for an adapter bracket that the car/derby caps would use to keep them secured. Look @ some car/vette ralley wheels & you can get an idea of what it might take. His set-up was pretty basic & looked like an inverted bar-stool.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
