Old 11-21-2009, 01:13 PM   #1
PDW HOTRODS
PDW HOTRODS's Avatar
LS engine computer.
I have seen , and thought about doing an LS engine swap, but what about the computer. This would go into a 1953 Chevy pickup. As far as geting the engine and trany, and puting them in, that is just fab work that I could do. But what are you guys doing for the computer. What does it cost to send it somewhere to have it modified, or do you have to? I have read you need to get the wireing and computer with the engine/trany, but then what? Thanks.
PDW HOTRODS is offline   Reply With Quote
Old 11-21-2009, 01:26 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: LS engine computer.
It depends on the transmission. If you run a TH400 , 700R4 or a 4L60/80e. You need the engine harness at minimum and the trans harness if you run an e version trans. LS1truck.com or LT1swap.com has some good info.
I'm looking at this same swap for a 58. The harness is the expensive part. I see companies will reprogram the PCM for $75 and redo the harness for up to $600.
dwcsr is offline   Reply With Quote
Old 11-21-2009, 03:38 PM   #3
Thealien
Thealien's Avatar
IMHO if your going for the engine why not get overdrive while your at it?
There are websites that will help you do your harness yourself to many others that charge as little as $300 up to $795 for a completely new harness.
I have decided on letting fellow board member 68 short step do mine. He has been very good at answering all my questions and I have seen his work all over this forum. He may not be the cheapest but you do get what you pay for.
You need the rear 02 sensors and VATS along with a couple of other things programmed out of the computer. I have not seen any as cheap as $75 but have seen $125-300+
Old 11-21-2009, 06:20 PM   #4
50adrod
50adrod's Avatar
I had my factory harness reworked for stand alone operation along with a pcm reprogram to eliminate vats and unwanted items along with a performance tune for around $300 by Jesse at wait4me performance
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 11-21-2009, 09:52 PM   #5
Kid
Kid's Avatar
Speartech reworked my computer & built my custom harness. Cost was approx. $1250.00 total, not cheap, but first rate quality & stands behind his product. I'll be using Speartech again for my next project.
Kid is offline   Reply With Quote
Old 11-22-2009, 12:04 AM   #6
50adrod
50adrod's Avatar
I have heard they do good work but if you do not need a custom harness or want to save a few bucks Jesse will fix you up, he has done two 5.3's for me and retunes if needed are free. I did a cam swap and he retuned it for no charge. I am sure there are others out there but this is just one I have experience with.
Old 11-22-2009, 12:19 AM   #7
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
I'll second your comment for Jesse, reasonable priced and does a great job on the harness, every wire is labeled, he gives lifetime retunes if you add aftermarket parts, Cam, heads, exhaust...
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 11-23-2009, 08:07 PM   #8
78-5.3
78-5.3's Avatar
Tri5
if you can get the guy on the phone or email !!! i had a harness reworked for $212 including the ob11 port i theres nothing really in them
78-5.3 is offline   Reply With Quote
Old 11-23-2009, 10:14 PM   #9
Tri5Nerd
Tri5Nerd's Avatar
I had no problem getting him to return my emails, he actually called me with a question when he was redoing my computer because he was unsure about something I wanted added.
Tri5.
