11-21-2009, 08:15 PM | #1 |
Eaton rearend
Does anybody out there make a cool looking diff cover for the Eaton rear end in my 1970 3/4 ton c20??
11-22-2009, 08:31 AM | #2 |
Six in a row makes it go...
Re: Eaton rearend
I doubt it. This is one differential that is not supported by the aftermarket. You can get some replacement bearings, but that's about it.
It's a great rear and I like mine, but it's tough to get parts for.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
11-22-2009, 11:24 AM | #3 |
20' Daredevil (Ret)
Re: Eaton rearend
Speaking of Eatons... a tidbit of info that might help someone.
Mine started growling -- not bad, barely enough to hear -- when coasting downhill. The pocket bearing (on the pinion) was slightly pitted. A new one from NAPA fixed it. That was several years ago, and it's still quiet.
11-22-2009, 10:28 PM | #4 |
Re: Eaton rearend
I got an Eaton in my 72 Cheyenne Super 3/4 ton 4x4 and have been wondering if there was a rhyme or reason as to getting the eaton or a dana,and which is better.
11-23-2009, 01:25 AM | #5 |
its all about the +6 inches
Re: Eaton rearend
the eaton is stronger by far.
big block 3/4 tons automaticly got the dana. many GMC trucks got it For the best part, most of the rest got the eaton. |
