Old 11-21-2009, 09:35 PM   #1
hwyix
How hard/much to install a 67 front clip?
I have been looking to buy a k5/blazer/jimmy for a while now. Some of the trucks I have have the 67 front clip. To my eyes I really like it.
My question is how difficult and how much would this cost to do? If it only cost $500 in parts then I will just buy the nicer truck. If it turns out this modification cost thousands of dollars I will probably chose the truck with tired motor and 67 front end.
Thanks for your input.
hwyix is offline   Reply With Quote
Old 11-21-2009, 09:54 PM   #2
vegaschevy
Re: How hard/much to install a 67 front clip?
You can pick up a complete front clip off of a 67/68 truck for 300-800 dollars. The only thing you will need to install it is the 67/68 Rad support mounts. Other then that it is a bolt on set up as far as I have found.
vegaschevy is offline   Reply With Quote
Old 11-21-2009, 11:55 PM   #3
Rokcrln
Rokcrln's Avatar
Very easy to do in a weekend. Buy the better of the trucks then stick a 67-68 front clip on it.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-22-2009, 05:05 AM   #4
hwyix
Thank you guys for clearing that up for me.
Old 11-22-2009, 10:50 AM   #5
andrewmp6
My question is what all parts need to be changed out?
andrewmp6 is offline   Reply With Quote
Old 11-22-2009, 10:56 AM   #6
Hart_Rod
Hart_Rod's Avatar
fenders, grille, core support, hood.....
Hart_Rod is offline   Reply With Quote
Old 11-22-2009, 11:11 AM   #7
andrewmp6
Is the front bumpers the same ? Thanks for a fast answer.
Old 11-22-2009, 11:17 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
The bumpers are the same i do believe up untill 71 when they moved the signal into the bumper. gmc bumpers are all the same except they have a small notch cut out on the top lip for the turn signals.. I could be off on this but if I am I am sure someone will correct me.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-22-2009, 01:17 PM   #9
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Bumpers are same until 71. Lights are in bumper.
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 11-22-2009, 10:26 PM   #10
hwyix
I am glad some else asked about all the parts. For some reason I thought it was just the grill, headlights, etc....
If you get all the parts for $800 (fenders, grill, hood, etc...). Won't it cost at least $1000 if not more to paint the fenders, hood, etc.... Sounds like a very easy swap but the true cost of the swap is probably around $1500 to $2000.
