I'm going to have my exhaust done like factory. New y-pipe & single cat, muffler & exit behind the rear tire. This is setup it has now but in 2". I want to go with all 2.5". Will I loose any power hooking it to the stock manifolds wich are 2" "I think"? Or would 2.25" be better? It a stock 350. TES headers are pretty much out of the question do to funds. Thanks.
Troy 1982 Silverado |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
You want be able to hook up 2.5" pipes directly to the manifolds. 2-1/4" is it. You can run 2.5" but you won't gain anything over the 2.25" with the manifolds. Your exhaust will only flow as much as the smallest restriction.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
You get what you pay for
Not to disagree with Capt, but I would go with 2.5, since it is single exhaust, you can most definetely use it. This is coming from someone who has fought the loosing battle of single exhaust. My feeling is the 2.5" will help, even if you do only have 2" exhaust manifolds.
Mike 1985 Chevy C-10 |
OOPS!, missed the single part! In that case, 2.5 would be fine after the Y pipe. I am going with 2.25" off the manifolds and mergine into a 3" on my Jimmy.
that is the way mine is but after the cat is 3"in
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
