Old 11-22-2009, 12:52 AM   #1
72BLUZ
72BLUZ's Avatar
Door speakers
hey guys, i am looking to install some speakers in my doors, and need ideas on how to run the wiring into the door. any info appreciated and some pictures would help as well!
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 11-22-2009, 08:40 AM   #2
Boog
laying low
Boog's Avatar
Re: Door speakers
No No Chuck!! Not speakers in the doors! That's considered by some to be one of the ultimate no nos. As long as it's done cleanly I don't mind and you are limited on how many places to put them in these trucks.
On the harness if you don't have power windows or locks already you could hit the salvage yards and grab a pair of rubber door to cowl tubes off some newer car or truck or do as some have and buy some polished flexible conduit to run the wires through. A rubber grommet on each end of it will keep it in place and no rubbing.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-22-2009, 10:19 AM   #3
kevmic28
kevmic28's Avatar
Re: Door speakers
This is what I am planning on using for my doors. large enough to run several different wires through it.
http://www.srbymichael.com/products/...re-looms.shtml
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 11-22-2009, 02:40 PM   #4
mvfd70
mvfd70's Avatar
Re: Door speakers
Or you could do something like this and have no wires at all to worry about. http://www.thehoffmangroup.com/keepi...c=doorcontacts
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 11-22-2009, 07:00 PM   #5
72BLUZ
72BLUZ's Avatar
Re: Door speakers
that is some interesting ways of doing it. Hey Boog i will not be cutting holes in the doors, just the door panel below the arm rest
Old 11-22-2009, 09:22 PM   #6
kevmic28
kevmic28's Avatar
Re: Door speakers
Only problem with that is once you open the door your speakers wont work.
1970 GMC truck
Old 11-22-2009, 10:08 PM   #7
72BLUZ
72BLUZ's Avatar
Re: Door speakers
this is true but think of the painless wiring as far as rubbed or pinched wiring goes
Old 11-22-2009, 10:36 PM   #8
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Unhappy Re: Door speakers
Hey 72, before you cut your door panels to install speakers, I thought I would warn you it does not sound good at all with the speakers in the door panels, because your body blocks most of the sound so you can't really hear them that well. I have two trucks that have them like this my 67 GMC and my 72 Chevy, the 67 has 6 1/2" 's and the 72 has 4x6"'s and I do not like the sound in either truck, it is too muffled!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 11-23-2009, 12:30 AM   #9
72BLUZ
72BLUZ's Avatar
Re: Door speakers
cant be no worse than the ones under the seat. but i think if i mount the ones i have under the arm rest would help. if it doesnt than back to square one, and a reason to get the new panels i want
Old 11-23-2009, 07:26 AM   #10
68Stepbed
68Stepbed's Avatar
Re: Door speakers
Chuckles, Why not kick panel speakers? Are you still using the stock fuel tank behind the seat?
If you go with with kick panel speakers, buy the blank panels, and go get some good speakers to put in them.
You can also look into BOSS speakers. They make different styles of speaker pods that can be mounted just about anywhere.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-23-2009, 08:39 AM   #11
CrashBob
CrashBob's Avatar
Re: Door speakers
Get a good dual core speaker to replace the original in the dash. You can hear it and you don't have to cut up anything.
One thing people seem to forget is road noise which nullifies any ''premium sound'' you might get when sitting in the garage. Our trucks are not designed with ''hi-fi'' sound systems in mind.
Speaking from lots of experience,
CrashBob
"Life is all about ass. You're either covering it,laughing it off, kicking it, kissing it, busting it or trying to get a piece of it.
CrashBob is offline   Reply With Quote
Old 12-02-2009, 08:27 PM   #12
72BLUZ
72BLUZ's Avatar
Re: Door speakers
i got the kick panel speakers and some under the seat, the ones under the seat are muffled and the kick panels are not loud enough to me
