11-22-2009, 02:28 AM | #1 |
Power steering pump and brackets
Hello,
I have a 72 c10 w/350. Want to install p/steering to her. Have a box and pump. Going to the local boneyard Sunday. Question: Does anyone have any pictures of the pump brackets I'm suppose to have.. installed? Also, The # on the side of the p/s box is 7802644. My bud said that it will work. Just want to make sure. Thanks for any advice.. Mark
--------------------------------- 72 C10 SWB 350 Work in progress 98 HD Fatboy 09 HD Heritage Softail 05 Honda Element |
11-22-2009, 08:12 AM | #2 |
Re: Power steering pump and brackets
There is a pump with the right brackets on ebay (not mine) which will show you the bracket. It is a two piece that cradles the pump. Two bolts on the front of the block and one on the front motor mount. Don't forget the crank pulleys. Item number is 320449659392
Last edited by rsavage; 11-22-2009 at 08:29 AM. Reason: link didn't work as planned |
11-22-2009, 08:26 AM | #3 |
Watch out for your cornhole !
Here's some pictures of mine and of one I powdercoated for Scoti. Be sure and get the extra add-on crank pulley from the junkyard too.
Disregard the alternator brackets in these pictures.
11-22-2009, 08:47 PM | #4 |
Perfect!! Thanks bro....
12-01-2009, 08:43 PM | #5 |
Do you know the Part #'s for the crank pulleys? I am trying to figure out what I need for my 67 283 non a/c. I am adding power steering and my pump and bracket look the same as yours and goes in that location.
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
12-01-2009, 09:04 PM | #6 |
I think that pulley is readily available from several of the Chevy truck and car trinket shops.
Here: http://www.google.com/search?source=...&aq=f&oq=&aqi= It looks like the same pulley fits cars and trucks so a used one might be easy to find. |
12-01-2009, 09:34 PM | #7 |
I don't have the numbers, but you might PM Scoti and see if he will read the numbers off the pulleys for you.
