Old 11-22-2009, 11:21 AM   #1
Legolas894
Chemist under the hood...
Legolas894's Avatar
Low Mount Alternator Bracket
The alternator bolt snapped off in the head while driving. Lucky for me, there was enough of a shard on the bolt that I could turn it out (very slowly) by hand.
I guess I have to address this issue, the PO had a strange set up with parts that could not have been stock. See first picture.
All I seem to find as a replacement are the chrome lower mount SBC, SWP brackets. It doesn't look like you have much adjustment with these. Is anyone using them? What did the stock brackets look like?
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 11-22-2009, 02:48 PM   #2
roger0080
Re: Low Mount Alternator Bracket
Correct me if I'm wrong but you don't have the 2 holes in the front of the head for the stock alternator bracket, guess that's why you have the funky setup you have.
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 11-22-2009, 03:40 PM   #3
Andy4639
Old member
Andy4639's Avatar
That's what I see also no bolt holes in the head to do it with.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-22-2009, 04:04 PM   #4
Legolas894
Legolas894's Avatar
Yes-All I've got are the two bolt holes below the water pump on the driver's side. Still wondering if the stock position was low (like I have) or some other bracket that attached to the intake manifold.
Current fleet:
Old 11-22-2009, 04:33 PM   #5
Boog
laying low
Boog's Avatar
That low mount concoction was not the original setup. I believe the correct alternator mount was a bracket bolted to the exhaust manifold on the pre 69 engines. It wasn't until 69 or so that the heads came with accessory holes in them.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-22-2009, 04:51 PM   #6
vectorit
What?
vectorit's Avatar
A long time ago I ran that chrome lower bracket for the alternator.
It was more trouble than it was worth so I pitched it, and went back to the OEM style bracketry.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 11-22-2009, 05:42 PM   #7
Legolas894
Legolas894's Avatar
That's what I want but I can't find a picture of the OEM style. Does it look like this on on ebay?
http://cgi.ebay.ca/ws/eBayISAPI.dll?...2#ht_500wt_975
Current fleet:
Old 11-22-2009, 05:47 PM   #8
william-theglassman
william-theglassman's Avatar
go to a salvage yard. get a alt. bracket from a older buick v6 . it will bolt up to the 2 holes on the block in front of the fuel pump.you will have to come up with a top adj. bracket piece.
william-theglassman is offline   Reply With Quote
Old 11-22-2009, 05:53 PM   #9
vectorit
What?
vectorit's Avatar
I think you may be in for some hassle... Since it looks like your driver side exhaust manifold doesn't have a mounting boss on it.
Here is how mine is set up.
Notice the shape of the upper adjuster braket, this one is the one the worked best for me. I went through many ebay purchases of different style upper brakets, only to find they didn't have the best arc to adjust the alternater with my lower braket set up.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 11-22-2009, 09:09 PM   #10
Legolas894
Legolas894's Avatar
Vectorit-Thanks for the beautiful pix. I think I have a cannibalized version of your set up. The adjusting hockey stick looks the same. Also, the s-shaped bracket that I have looks similar to the one on your exhaust manifold. Are two holes on the exhaust manifold required for your setup (alternator pivot goes all the way through or just into the bracket)?
I wonder if there is a modification.
WHY IS THIS SO COMPLICATED!!!!
I'm missing out driving my truck on these great days. Winter is coming soon.
Thanks again for the pictures. I'd still like to see anyone else's setup especially on a '67 283.
Current fleet:
Old 11-23-2009, 11:27 PM   #11
Legolas894
Legolas894's Avatar
Any other pics of bracket options?
Current fleet:
Old 11-24-2009, 12:15 AM   #12
vectorit
What?
vectorit's Avatar
I'd see about getting a ram exhaust manifold for the driver side with the alternator mounting boss, then you could set up the brackets like how mine are. The lower you can get anywhere, and the upper you may have to search a little bit. But at least you will be on the right track, and be back on the road more reliably sooner.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 11-24-2009, 10:24 PM   #13
Legolas894
Legolas894's Avatar
Thanks Vectorit!
Current fleet:
